Heading for 2nd no show in 24hrs
- Feedback
- Plusnet Feedback
- Re: Heading for 2nd no show in 24hrs
10-06-2014 11:29 AM
The BT profile figure is wrong - May be DCT can get it poked in BT's systems. This seems to be a recent reoccurring theme.
Kevin
10-06-2014 11:45 AM
10-06-2014 11:49 AM
10-06-2014 11:50 AM
Not seeking to argue your assertion, but usually the only thing which can be set is the target SNRM. IP profile follows the synch speed - it should be 88.2% of the synch speed. DCT will hopefully pick this up. Would be worthwhile updating your ticket on this point.
Kevin
10-06-2014 11:54 AM
Ignore what Kevin has posted - he's either overlooking that you are on 20CN or ignorant of the differences.
10-06-2014 12:09 PM
From engineers report. "port reset and BRAS reset now in sync at 1824 kbps down 448kbps up snr7" ?
That was yesterday, and the IP at the exchange was showing as 1.5 , it took a while for PN to catch up last night and then this morning it was down the pan again at 1 Mbps
Make of that what you will, I do 'puters, I don't really do all this broadband signal/speed/SNR nonsense.
10-06-2014 12:19 PM
There's a lot of good information here: http://www.kitz.co.uk/adsl/IPprofile.htm
10-06-2014 12:36 PM
A bit of reading for me then.
At first glance the IP should be 1.25, if and when it catches up. Ongoing fault I'm afraid then, despite the engineer's work yesterday. It stabilises for months at 1.5 and then we are back to this, at worst it goes to 0.14
Thanks again
10-06-2014 1:27 PM
I'm aware Tom is still monitoring your account on Ticket: 85534360 - can you update the ticket with any information for Tom to investigate further for you if required?
10-06-2014 1:39 PM
Also presumed he would see the drop in speed again, would he not?
Thank you
10-06-2014 1:42 PM
Quote from: jelv Ignore what Kevin has posted - he's either overlooking that you are on 20CN or ignorant of the differences.
Hi Jelv,
I think I know of you well enough to know your intent was well meant, but you could have said that a little better with a link to the clarification in the first instance, if only for Karen's benefit. You are though quite right, I had forgotten the different characteristics of 20CN.
Karen,
Sorry for any confusion I might have caused.
Kevin
10-06-2014 1:47 PM
Still not altogether clear about the role of DLM - in reaction times going up, one place seems to say 5 days, another 3 and a third, says it is dependent on the percentage amount of the change. Yikes.
10-06-2014 1:49 PM
10-06-2014 1:54 PM
If your speed is fluctuating, it might be worthwhile installing RouterStats to closely monitor line performance. Do ask if you need help configuring it, somehow I doubt that YOU will have any difficulty with it. Running it 24x7 can tell you an awful lot about what is happening.
Kevin
10-06-2014 1:57 PM
Done anyway.
