HELP - No broadband since activation 2 weeks ago
- Feedback
- Plusnet Feedback
- Re: HELP - No broadband since activation 2 weeks a...
- « Previous
- 1
- 2
- Next »
Re: HELP - No broadband since activation 2 weeks ago
15-09-2009 2:08 PM
I'd be interested to hear if your Sky details still work
15-09-2009 2:11 PM
15-09-2009 2:26 PM
I'll be back in touch as soon as I hear anything.
15-09-2009 2:48 PM
I was on a normal BT line, with calls placed through TalkTalk (i.e. not LLU). Broadband was through Sky. I cancelled Sky as my parents were going to be away for 2 months (and they didn't watch it much anyway) and downgraded to Freesat. At that time I asked for a MAC as Sky wouldn't let me take broadband without their TV service. I got the letter with the MAC without problem which said the MAC was valid for 30 days from 15 July. I tried to use the MAC on 8th August but this was rejected, reason being it was for a different phone number! I tried to get another MAC but instead Sky just cut me off on 15 August for some reason still unknown. They informed me that the marker would be cleared from my line ready for another provider from 22nd August.
At this point, Plusnet came in and authorised a new connection and you know the rest......
(I would like to point out that Plusnet were very helpful up to this point and that is why I have given them so many chances to get it right).
Shaileen.
15-09-2009 2:53 PM
15-09-2009 2:55 PM
My apologies - I was under the impression that you'd gone through the Migration procedure as normal. Sounds like Sky really messed things up for you - however with James on the case, I'm sure it'll get sorted out soon
15-09-2009 3:17 PM
15-09-2009 9:24 PM
15-09-2009 10:46 PM
I'm guessing it was a new provide as I couldn't supply a valid MAC. Broadband is active on the telephone line but I can't connect using either my Plusnet login details or the BT test ones (or my old Sky details although I'm not sure if they're correct). The Thomson modem shows a green "broadband" light but the "internet" light is either off or red.
This is what my account shows if it helps anybody (in approximate date order depending on when Question Topic was closed). It doesn't make much sense to me but it may do to someone. The only thing I can think of that may be causing my problem is that I have actually been migrated from Sky somehow and then Sky has ceased my broadband connection basically causing the Plusnet connection to connect to nothing but that is all guesswork as I have no idea how this whole migration thing works!
Here goes....
-Provisioning of your ADSL Account Information
Install diary status changed from Migrating from another ISP to Realm configured
New Action Pass/Informative response from BT added
Customer application has been rejected by BT
New Action Invalid Details added
Install diary status changed from Application Submitted to Application Rejected
-Account has been processed by ADSL In Progress script
The ADSL commit date is:- 25/08/2009
Customer Activation Date will be after 12pm on the 26/08/2009
Action Pass/Informative response from BT cleared
BT Reference Number set to BBIP********. BT Circuit Number set to CBUK********
Install diary status changed from Application Rejected to Migrating from another ISP
Install diary status changed from Migrating from another ISP to No Static IPs
The following statuses have been cleared as a result of using the Configure Static IP tool
- Invalid Details
Install diary status changed from No Static IPs to Awaiting supplier selection
Due to Configure IP tool use
This ADSL account has selected dynamic IP, no IP address needs to be configured.
Install diary status changed from Awaiting supplier selection to Migrating from another ISP
Install diary status changed from Migrating from another ISP to Awaiting supplier selection
Install diary status changed from Migrating from another ISP to Supplier processing
Install diary status changed from Supplier processing to ADSL Active
ADSL activated
17-09-2009 7:27 AM
17-09-2009 7:47 AM
17-09-2009 9:54 AM
17-09-2009 1:16 PM
Thanks for your efforts James.
17-09-2009 1:19 PM
I'll sort out a monetary gesture for the downtime.
- « Previous
- 1
- 2
- Next »
- Feedback
- Plusnet Feedback
