From Value to Premium- Why did I bother?
- Feedback
- Plusnet Feedback
- From Value to Premium- Why did I bother?
07-01-2010 2:35 PM
I upgraded from Value to premium as I got a bit fedup of the throttles and having to download big files at night time.
Solution - Upgrade to Premium? NO!
I have 80 gig limit now but I can only get good speeds after midnight.
E.g right now 14.33 when it is supposed to be line speed for web downloads I am averaging 100kbs tops 220kbs when my old ISP was well over 300kbs!!
5 REPLIES 5
Re: From Value to Premium- Why did I bother?
07-01-2010 2:41 PM
Do you know what your current IP profile is? You can find this by doing a BT Speedtest.
07-01-2010 2:53 PM
If your peak usage is less than 20GB you'd have done far better to move to Pro!
07-01-2010 3:07 PM
Quote from: Mand Hi there,
I get to testing please wait and it hangs for a long time?
07-01-2010 3:09 PM
Quote from: jelv If your peak usage is less than 20GB you'd have done far better to move to Pro!
I moved from a 9.99 service to plusnet as I was an ex customer and knew I would have a solid connection.
I dont want to pay more than £15.99 a month
07-01-2010 4:13 PM
Quote from: Cos2010 I get to testing please wait and it hangs for a long time?
It does hang sometimes but it should return a result.
Failing that, do you know what your router stats are?
