Findings After Rejoining Plusnet
Donnygal
Re: FINDINGS AFTER REJOINING PLUSNET
Well the ebayer did great and it arrived today, tried setting it up, even spoken to PN and gone through options, and currently cannot see a fault but not connecting to the internet.  Does anyone have a Zyxel VMG3925-B10C.and can advise
Changed the logon name and password, and checked the password, left all other options as automatic as recommended by PN.  Screenshot below
Moderator's note by Dick (Strat): Personal information removed from attachment.
notmyname
You may want to edit your picture, your Plusnet username is in it.
RealAleMadrid
Fixes: 68
@Donnygal  Having looked through your posts I can't see which Broadband service you have. Usually you get a Plusnet Hub1 router for VDSL services such as Unlimited Fibre. (Fibre to the Cabinet or FTTC). You have set up your Zyxel for ADSL which is older slower broadband.
If you have FTTC some configuration changes are need. Basically Type - VDSL over PTM, IPv4 only (Plusnet do not support IPv6)
Also this is important VLAN 802.1p value 101 VLAN 802.1q value 1 or 2 not sure if it makes a difference
MTU 1492 is the default for PPPoE connections
If you are on ADSL apart from the IPv6 not needed and the MTU value it looks OK.
Hope this helps to get the zyxel going.😁
Donnygal
Thanks, after re-reading twice, have now set up a VDSL connection and am just going to try it, keep your fingers crossed.
Donnygal
Europa!  Up and running, thanks for the info, and your patience guys. DG
