Fibre Optic Worse Than Adsl
- Feedback
- Plusnet Feedback
- Fibre Optic Worse Than Adsl
20-08-2014 7:39 AM
Re: Fibre Optic Worse Than Adsl
20-08-2014 8:12 AM
What does it say for Current Line Speed here - https://portal.plus.net/my.html?action=data_transfer_speed ?
You can get compensated for the missed appointment slot.
20-08-2014 8:26 AM
20-08-2014 8:27 AM
20-08-2014 8:47 AM
20-08-2014 9:12 AM
Run the BTw Performance test (ignore the red preamble except make sure no other programs are using the Internet) and at the end of the first run, click the Further Diagnostics button, enter just your Phone number and Run the Further Diagnostics Test.
Do a Copy and Paste of the results and post here (no need to grab an image).
Again check your Current Line speed (Login required)
It's got nothing to do with "stone-age", it's simply that your profile hasn't updated to match the new BT IP Profile.
@Plusnet - What is the matter with CSC WHY aren't updates to Current Line Speed not being implemented when a customer phones in. This should be a matter of routine, not all this BS about oh a supervisor will call you back - no wonder you can't handle the volume of calls and tickets
Also, why are we seeing an increased frequency of this issue when people move to Fibre, the Current Line speed was being set to the default 78Mbps (or 38Mbps?) awaiting the first automatic profile update?
20-08-2014 9:19 AM
Quote from: Anotherone @Plusnet - What is the matter with CSC WHY aren't updates to Current Line Speed not being implemented when a customer phones in. This should be a matter of routine, not all this BS about oh a supervisor will call you back - no wonder you can't handle the volume of calls and tickets
+1
I also have to question why PN did not put a service status yesterday about an authentication issue for new users (several already posted on here and a number on Twitter).
20-08-2014 9:24 AM
20-08-2014 9:26 AM
20-08-2014 9:27 AM
@Roadie, a tip, whilst screenshots can sometimes be useful, usually a plain text copy and paste of speedtest results is usually good enough.
20-08-2014 9:58 AM
20-08-2014 10:04 AM
Thank you for the courtesy call this morning, am glad that you picked this up on the forum given that the member of staff who, last night, logged me for a supervisor call this morning, did not actually do it !! Download speed now bouncing between 17- 43 meg, am assuming that this will settle down but will monitor it to make sure.
Thanks too, to the members who responded to this thread, much appreciated,
20-08-2014 10:06 AM
Linn, could you get some one to answer that please.
20-08-2014 10:20 AM
Admittedly, this could've been resolved yesterday when the OP called in the spoke to the advisor so I will be feeding that back internally.
Roadie, glad to hear the speed's on the up for you
20-08-2014 10:25 AM
