Fed up with router return bags!
- Feedback
- Plusnet Feedback
- Re: Fed up with router return bags!
- « Previous
- Next »
20-01-2014 3:02 PM
20-01-2014 3:36 PM
Quote plusnet called ben spoke to an engineer to sort out the problem but nothing has been done
Not quite the case that nothing has been done but the work we did to stop this on our accounting systems seems to have revealed that the problem is at the warehouse.
I'm going to speak with Ben now and see what we can do to put a stop to this once and for all. I'll also get some more labels sorted, how many do you need?
Adam
20-01-2014 3:38 PM
20-01-2014 3:39 PM
Quote from: _Adam_Walker_ Not quite the case that nothing has been done but the work we did to stop this on our accounting systems seems to have revealed that the problem is at the warehouse.
I cannot believe that you hadn't looked in to this possibility long before now! Surely you could have asked that someone at the warehouse was tasked with checking the returns bags each day to make sure none were sent to jasonfreeman
20-01-2014 3:41 PM
Are the labels on the bags with your address identical? I wondered if there was something like a batch number somewhere on them.
Edit: You could post a tweet saying "You've got a week and a bit to get your shit together otherwise I'm blowing the warehouse sky high!!" but that might not be a good idea!
20-01-2014 3:43 PM
20-01-2014 3:43 PM
I've spoken to Ben and the warehouse have assured us this should have stopped now. The ones that have reached you today were the last ones to have been dispatched on Friday so there should be no more now. I'm now also aware we sent you 8 labels on Friday.
20-01-2014 4:03 PM
20-01-2014 4:09 PM
20-01-2014 4:12 PM
20-01-2014 4:55 PM
20-01-2014 4:58 PM
20-01-2014 9:54 PM
- « Previous
- Next »
