Fed up with ping times from Hell
- Feedback
- Plusnet Feedback
- Fed up with ping times from Hell
Re: Fed up with ping times from Hell
03-01-2014 6:27 PM
Run traceroute -I or traceroute -T instead.
06-01-2014 7:53 PM
However I am now encountering high ping times again.
Overall it's been better since I been moved over to a static IP but I am still getting spikes now and then as my graph shows.
07-01-2014 8:23 PM
Seriously what the hell is going on with my line? -- Who can I contact to get this fixed.
Mods: Sorry for the double post. But I am getting fed up with being ignored.
Edit: 11:38pm - 7th Jan - Packet Loss, Ping Times Everything.
ping bbc.co.uk
Pinging bbc.co.uk [212.58.251.195] with 32 bytes of data
Reply from 212.58.251.195: bytes=32 time=409ms TTL=119
Reply from 212.58.251.195: bytes=32 time=449ms TTL=119
Reply from 212.58.251.195: bytes=32 time=530ms TTL=119
Reply from 212.58.251.195: bytes=32 time=525ms TTL=119
Ping statistics for 212.58.251.195:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
Approximate round trip times in milli-seconds:
Minimum = 409ms, Maximum = 530ms, Average = 478ms
Tracing route to bbc.co.uk [212.58.251.195]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms home.gateway.home.gateway [192.168.1.254]
2 871 ms 909 ms 943 ms lo0-central10.ptw-ag02.plus.net [195.166.128.196
3 474 ms 253 ms 24 ms link-b-central10.ptw-gw02.plus.net [212.159.2.15
0]
4 496 ms 517 ms 542 ms xe-0-2-0.ptw-cr02.plus.net [212.159.0.250]
5 625 ms 645 ms 646 ms ae2.ptw-cr01.plus.net [195.166.129.4]
6 724 ms 750 ms 749 ms kingston-gw.thdo.bbc.co.uk [212.58.239.6]
7 * * * Request timed out.
8 * * * Request timed out.
9 1347 ms 1370 ms 1430 ms ae0.er01.telhc.bbc.co.uk [132.185.254.109]
10 795 ms 750 ms 815 ms 132.185.255.140
11 978 ms 1016 ms 983 ms 212.58.251.195
Trace complete.
This is just driving me nuts. Seriously Plus. Can I get a reply please?
08-01-2014 9:37 AM
Quote 1 <1 ms <1 ms <1 ms home.gateway.home.gateway [192.168.1.254]
You're seeing the high pings starting between your modem and our first hop. This means either the gateway is struggling (which it isn't as we'd see a much larger number of problems!) or the problem is somewhere from your modem, through your line, exchange and back haul to us. More than likely it's your line!
Can you go to http://faults.plus.net and raise a fault for us to investigate. You started one back in September, but didn't complete all the questions so it closed off a few days later
I don't supposed you've got a spare router handy so you can prove it isn't your router? (Sorry if you've mentioned that in the thread already)
Ex-Plusnet Jobsbody
08-01-2014 9:42 AM
08-01-2014 10:16 AM
I've tried two different routers.
My Billion 7000n and my own router with an ADSL card. Both give me high latency.
I think its more a gateway issue then a router issue. So far I've had more trouble using -ag02.plus.net. but when I was on ag08.plus.net everything was wonderful.
I've never had any problems with any other providers (such as BT, and Be*)
If I reboot the router I have perfect pings (22ms or lower) for around five minutes and then it just spikes like so.
I skipped the faults.plus.net because I don't want to be asked "have you tried turning your router on and off again".
However I will raise a ticket.
@AndyH
I have a BT line and confirm that that there is no noise/static on the line.
08-01-2014 10:23 AM
Quote from: Yaroze @Kelly,
Good. Will be a fault then.
Quote from: Yaroze I think its more a gateway issue then a router issue. So far I've had more trouble using -ag02.plus.net. but when I was on ag08.plus.net everything was wonderful.
You need to supply the PCL/PTW in front of the gateway addresses for us to know which you are referring. It's always possible that we have a hardware issue, but it would be affecting a lot of customer if so.
Quote from: Yaroze I've never had any problems with any other providers (such as BT, and Be*)
Who were you with before you came to is? BT or BE? If it was BE, it could be a knock on from moving from their LLU product.
Quote from: Yaroze If I reboot the router I have perfect pings (22ms or lower) for around five minutes and then it just spikes like so.
Please fill it in and answer them all. It start the whole process off and makes sure that the simple things (checking with a new router, making sure you've microfilters on all phones/sky boxes are covered). It shouldn't take long at all, and will save a bounce back to you.
Ex-Plusnet Jobsbody
08-01-2014 10:54 AM
Quote Fed up with ping times from Hell
Would that be Hell, Michigan?
08-01-2014 11:33 AM
ptw-ag02.plus.net
ptw-ag04.plus.net
ptw-ag06.plus.net
ptw-ag08 was pretty reasonable.
I was rebooting my router to change the route path.
I've now created a support ticket and my previous provider was Be* back in July.
Thanks you for your help.
08-01-2014 11:42 AM
Ex-Plusnet Jobsbody
08-01-2014 11:51 AM
Quote from: Yaroze I was rebooting my router to change the route path.
Don't!
Frequent reboots may be seen by the DLM in the exchange as instability and it will slow your speeds in an attempt to stabilise the line.
Go in to the router interface and click Disconnect then Connect. That drops the PPP session without dropping sync with the exchange. It will (usually - unless you get unlucky) connect you to a different gateway.
08-01-2014 12:00 PM
That's what I mean by "reboot" not actually reboot the router, I should of really written "Disconnect" -- My mistake.
08-01-2014 1:23 PM
Totally a stab in the dark but when a home hosted website got a little too popular a few years ago I had very similar issues with intermittent high latency issues and ping times through the roof.
09-01-2014 9:32 AM
Apart from an odd P2P Game (Borderlands) no other services are being ran.
14-01-2014 8:26 PM
No reply to ticket since then.. and still sucky broadband.
Sorry for double posting. But I've done everything from the handbook down to the forum. If this is an unfixable problem please just say and I'll move elsewhere.
