Fed up with ping times from Hell
- Feedback
- Plusnet Feedback
- Fed up with ping times from Hell
03-01-2014 12:11 AM
This is now just getting beyond stupid.
Every day I always seem to encounter issue with high pings. I've posted on forums and bought it up with support however never had any real resolve to the problem.
Like right now, 11:56pm
Pinging bbc.co.uk [212.58.251.195] with 32 bytes of data:
Reply from 212.58.251.195: bytes=32 time=63ms TTL=118
Reply from 212.58.251.195: bytes=32 time=55ms TTL=118
Reply from 212.58.251.195: bytes=32 time=245ms TTL=118
Reply from 212.58.251.195: bytes=32 time=988ms TTL=118
Reply from 212.58.251.195: bytes=32 time=1156ms TTL=118
Reply from 212.58.251.195: bytes=32 time=1221ms TTL=118
Reply from 212.58.251.195: bytes=32 time=1229ms TTL=118
Request timed out.
Reply from 212.58.251.195: bytes=32 time=855ms TTL=118
Reply from 212.58.251.195: bytes=32 time=883ms TTL=118
Reply from 212.58.251.195: bytes=32 time=910ms TTL=118
Reply from 212.58.251.195: bytes=32 time=958ms TTL=118
Reply from 212.58.251.195: bytes=32 time=1006ms TTL=118
Reply from 212.58.251.195: bytes=32 time=999ms TTL=118
Reply from 212.58.251.195: bytes=32 time=770ms TTL=118
Reply from 212.58.251.195: bytes=32 time=853ms TTL=118
Reply from 212.58.251.195: bytes=32 time=282ms TTL=118
Reply from 212.58.251.195: bytes=32 time=506ms TTL=118
Reply from 212.58.251.195: bytes=32 time=531ms TTL=118
Reply from 212.58.251.195: bytes=32 time=585ms TTL=118
Reply from 212.58.251.195: bytes=32 time=695ms TTL=118
Reply from 212.58.251.195: bytes=32 time=735ms TTL=118
Tracing route to bbc.co.uk [212.58.251.195]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms home.gateway.home.gateway [192.168.1.254]
2 824 ms 249 ms 246 ms lo0-central10.pcl-ag05.plus.net [195.166.128.186
3 21 ms 21 ms 21 ms link-b-central10.pcl-gw02.plus.net [212.159.2.17
8]
4 20 ms 20 ms 21 ms xe-1-2-0.pcl-cr02.plus.net [212.159.0.210]
5 38 ms 21 ms 22 ms ae2.pcl-cr01.plus.net [195.166.129.6]
6 21 ms 21 ms 21 ms ae1.ptw-cr01.plus.net [195.166.129.0]
7 21 ms 21 ms 21 ms kingston-gw.thdo.bbc.co.uk [212.58.239.6]
8 * * * Request timed out.
9 * * * Request timed out.
10 942 ms 1014 ms 1015 ms ae0.er01.telhc.bbc.co.uk [132.185.254.109]
11 793 ms 683 ms 707 ms 132.185.255.140
12 929 ms 953 ms 979 ms 212.58.251.195
I am seriously getting frustrated here. As it appears to be your "AG" routes that are currently overloaded
Update:
I rebooted my router, different route. This time AG02
2 960 ms 968 ms 993 ms lo0-central10.ptw-ag02.plus.net [195.166.128.196
3 * 623 ms 672 ms link-a-central10.ptw-gw01.plus.net [212.159.2.14
8]
4 695 ms 572 ms 394 ms xe-0-2-0.ptw-cr01.plus.net [212.159.0.248]
5 368 ms 405 ms 488 ms kingston-gw.thdo.bbc.co.uk [212.58.239.6]
Upstream 444
Downstream 9703
SNR Margin(Upstream) 29.3
SNR Margin(Downstream) 2.2
Line Attenuation(Upstream) 21.2
Line Attenuation(Downstream) 34.5
This is intermittent, sometimes hours can go by and the net is fantastic.. however like now when I am trying to use the Internet at non-peak time.. its hell.
Why plus? Why.
Re: Fed up with ping times from Hell
03-01-2014 12:53 AM
03-01-2014 1:07 AM
I receive no Errors or Drops on both Upload and Download during the PING spikes.
03-01-2014 1:17 AM
03-01-2014 7:05 AM
Also, all the gateways have ag in their names - pcl-ag04 is not the same as ptn-ag04.
03-01-2014 9:07 AM
03-01-2014 9:38 AM
03-01-2014 12:15 PM
03-01-2014 12:56 PM
03-01-2014 3:13 PM
I've updated the graph in my previous post to reflect the new static IP.
However traceroutes are now failing to display the whole route.
traceroute to google.com (212.56.71.219), 30 hops max, 60 byte packets
1 home.gateway.home.gateway (192.168.1.254) 0.753 ms 1.060 ms 1.311 ms
2 lo0-central10.pcl-ag08.plus.net (195.166.128.189) 22.553 ms 23.436 ms 25.664 ms
3 link-b-central10.pcl-gw02.plus.net (212.159.2.190) 27.345 ms 29.827 ms 31.006 ms
4 xe-9-1-0.pcl-cr02.plus.net (212.159.0.222) 32.823 ms 35.061 ms 36.411 ms
5 ae2.pcl-cr01.plus.net (195.166.129.6) 38.919 ms 40.191 ms 42.604 ms
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
traceroute to bbc.co.uk (212.58.253.67), 30 hops max, 60 byte packets
1 home.gateway.home.gateway (192.168.1.254) 0.654 ms 0.923 ms 1.208 ms
2 lo0-central10.pcl-ag08.plus.net (195.166.128.189) 35.054 ms 36.093 ms 36.303 ms
3 link-b-central10.pcl-gw02.plus.net (212.159.2.190) 27.175 ms 29.555 ms 31.024 ms
4 xe-9-1-0.pcl-cr02.plus.net (212.159.0.222) 102.054 ms 102.291 ms 102.896 ms
5 ae2.pcl-cr01.plus.net (195.166.129.6) 38.936 ms 41.370 ms 42.578 ms
6 ae1.ptw-cr01.plus.net (195.166.129.0) 44.852 ms 38.037 ms 40.247 ms
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
Is this normal?
03-01-2014 3:20 PM
03-01-2014 3:26 PM
dick:quote
03-01-2014 3:45 PM
Tracing route to bbc.co.uk [212.58.253.67]
1 51 ms 1 ms 4 ms 192.168.1.1
2 13 ms 9 ms 8 ms lo0-central10.pcl-ag04.plus.net [195.166.128.185
3 8 ms 8 ms 8 ms link-a-central10.pcl-gw01.plus.net [212.159.2.17
2]
4 11 ms 11 ms 31 ms xe-0-2-0.pcl-cr01.plus.net [212.159.0.204]
5 8 ms 10 ms 8 ms ae1.ptw-cr01.plus.net [195.166.129.0]
6 8 ms 8 ms 68 ms kingston-gw.thdo.bbc.co.uk [212.58.239.6]
7 * * * Request timed out.
8 12 ms 11 ms 9 ms ae0.er01.cwwtf.bbc.co.uk [132.185.254.93]
9 9 ms 9 ms 11 ms 132.185.255.156
10 10 ms 9 ms 10 ms www-vip.cwwtf.bbc.co.uk [212.58.253.67]
Trace complete.
03-01-2014 4:02 PM
Are you running the pings/traceroutes wired or wirelessly?
03-01-2014 4:30 PM
My PC (running Linux), Nexus 5 and my router are the only devices on my network. All connected via wire (apart from my Phone)
dick:quote
