Fed up with ping times from Hell
jelv
Fixes: 10
Re: Fed up with ping times from Hell
Quote from: Yaroze
Apart from an odd P2P Game (Borderlands) no other services are being ran.
Do you terminate the P2P process or is it left running in the background?
If you are using Windows I suggest you install NetWorX to monitor activity.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Yaroze
Terminated. Once the game is closed, the net session closed. Just like any other online game.
However I'm actually using Linux.
Yaroze
Bumping..
The problem was resolved for a few months since changing to static IP. However I am now encountering the same issue again.
Tracing route to bbc.co.uk [212.58.244.18]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    1 ms  home.gateway.home.gateway [192.168.1.254]
  2  485 ms  527 ms  523 ms  lo0-central10.pcl-ag02.plus.net [195.166.128.18
  3  611 ms  610 ms  638 ms  link-a-central10.pcl-gw01.plus.net [212.159.2.1
4]
  4  661 ms  689 ms  731 ms  xe-10-1-0.pcl-cr01.plus.net [212.159.0.196]
  5  760 ms  810 ms  809 ms  ae1.ptw-cr01.plus.net [195.166.129.0]
  6  781 ms  485 ms  458 ms  kingston-gw.thdo.bbc.co.uk [212.58.239.6]
  7    *        *        *    Request timed out.
  8    *        *        *    Request timed out.
  9  1620 ms    79 ms    26 ms  ae0.er01.telhc.bbc.co.uk [132.185.254.109]
10    77 ms    35 ms    86 ms  132.185.255.149
11    31 ms    55 ms    52 ms  fmt-vip72.telhc.bbc.co.uk [212.58.244.18]
  2  815 ms  566 ms  589 ms  lo0-central10.pcl-ag08.plus.net [195.166.128.18
4]
  4  681 ms  689 ms  731 ms  xe-10-1-0.pcl-cr01.plus.net [212.159.0.196]
  5  560 ms  810 ms  809 ms  ae1.ptw-cr01.plus.net [195.166.129.0]
  6  7`1 ms  485 ms  458 ms  kingston-gw.thdo.bbc.co.uk [212.58.239.6]
VileReynard
Fixes: 20
It's fine for me.  Grin Grin Grin
jeremy@hector:~$ ping hell.co.uk
PING hell.co.uk (82.98.86.166) 56(84) bytes of data.
64 bytes from www166.sedoparking.com (82.98.86.166): icmp_seq=1 ttl=47 time=28.0 ms
64 bytes from www166.sedoparking.com (82.98.86.166): icmp_seq=2 ttl=47 time=26.3 ms
64 bytes from www166.sedoparking.com (82.98.86.166): icmp_seq=3 ttl=47 time=25.4 ms
64 bytes from www166.sedoparking.com (82.98.86.166): icmp_seq=4 ttl=47 time=25.5 ms
64 bytes from www166.sedoparking.com (82.98.86.166): icmp_seq=5 ttl=47 time=30.5 ms
^C
--- hell.co.uk ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4005ms
rtt min/avg/max/mdev = 25.484/27.202/30.592/1.942 ms
Yaroze
Wish I could say the same thing..
Tracing route to hell.co.uk [82.98.86.166]
  1    <1 ms    <1 ms    <1 ms  home.gateway.home.gateway [192.168.1.254]
  2  151 ms    97 ms  129 ms  lo0-central10.ptn-ag04.plus.net [195.166.128.193
  3  189 ms  266 ms  280 ms  link-a-central10.ptn-gw01.plus.net [212.159.2.14
0]
  4  284 ms  302 ms  322 ms  xe-8-2-0.ptw-cr01.plus.net [212.159.0.116]
  5  373 ms  460 ms  467 ms  te-3-4.car5.London1.Level3.net [217.163.45.181]
  6  415 ms  447 ms  474 ms  ae-52-52.csw2.London1.Level3.net [4.69.139.120]
  7  491 ms  492 ms  479 ms  ae-56-221.ebr2.London1.Level3.net [4.69.153.129]
  8  583 ms  603 ms  604 ms  ae-21-21.ebr2.Frankfurt1.Level3.net [4.69.148.18
6]
  9  681 ms  697 ms  735 ms  ae-72-72.csw2.Frankfurt1.Level3.net [4.69.140.22
10    *      284 ms  128 ms  ae-2-70.edge4.Frankfurt1.Level3.net [4.69.154.72
11  2225 ms  520 ms  134 ms  te2-2.c102.f.de.plusline.net [212.162.24.58]
12    36 ms    35 ms    40 ms  82.98.102.13
13  1001 ms  1382 ms  762 ms  c321.f.de.plusline.net [82.98.98.10]
14  1945 ms  1685 ms  866 ms  82.98.92.146
15    56 ms    80 ms  120 ms  gw-dist-pl-a.fhe3rz.net [91.195.240.2]
16  166 ms  205 ms  192 ms  www166.sedoparking.com [82.98.86.166]
Trace complete.
VileReynard
Fixes: 20
You get a different routing - mine doesn't even complete.
jeremy@hector:~$ traceroute hell.co.uk
traceroute to hell.co.uk (82.98.86.166), 30 hops max, 60 byte packets
1  ROUTER (192.168.1.1)  2.134 ms  2.086 ms  2.052 ms
2  lo0-central10.pcl-ag03.plus.net (195.166.128.184)  38.784 ms  39.291 ms  39.862 ms
3  link-a-central10.pcl-gw01.plus.net (212.159.2.168)  38.633 ms  39.171 ms  39.769 ms
4  xe-10-2-0.pcl-cr01.plus.net (212.159.0.200)  40.697 ms  40.671 ms  40.646 ms
5  xe-11-2-0.edge3.London2.Level3.net (212.187.201.213)  41.231 ms xe-11-1-0.edge3.London2.Level3.net (212.187.201.209)  41.203 ms  41.742 ms
6  vl-3201-ve-128.ebr2.London2.Level3.net (4.69.202.177)  52.646 ms  52.711 ms  54.677 ms
7  ae-44-44.ebr1.Paris1.Level3.net (4.69.159.94)  56.703 ms ae-42-42.ebr1.Paris1.Level3.net (4.69.159.86)  26.182 ms ae-44-44.ebr1.Paris1.Level3.net (4.69.159.94)  28.428 ms
8  ae-81-81.csw3.Paris1.Level3.net (4.69.161.86)  33.084 ms ae-71-71.csw2.Paris1.Level3.net (4.69.161.82)  33.589 ms  33.563 ms
9  ae-82-82.ebr2.Paris1.Level3.net (4.69.161.101)  34.825 ms ae-72-72.ebr2.Paris1.Level3.net (4.69.161.97)  35.676 ms ae-62-62.ebr2.Paris1.Level3.net (4.69.161.93)  36.851 ms
10  ae-46-46.ebr1.Frankfurt1.Level3.net (4.69.143.137)  39.350 ms ae-48-48.ebr1.Frankfurt1.Level3.net (4.69.143.145)  41.252 ms ae-47-47.ebr1.Frankfurt1.Level3.net (4.69.143.141)  46.581 ms
11  ae-61-61.csw1.Frankfurt1.Level3.net (4.69.140.2)  45.716 ms ae-81-81.csw3.Frankfurt1.Level3.net (4.69.140.10)  47.902 ms ae-61-61.csw1.Frankfurt1.Level3.net (4.69.140.2)  50.151 ms
12  ae-3-80.edge4.Frankfurt1.Level3.net (4.69.154.136)  51.562 ms ae-4-90.edge4.Frankfurt1.Level3.net (4.69.154.200)  54.458 ms ae-2-70.edge4.Frankfurt1.Level3.net (4.69.154.72)  26.252 ms
13  te2-2.c102.f.de.plusline.net (212.162.24.58)  30.854 ms  34.435 ms  34.405 ms
14  82.98.102.13 (82.98.102.13)  34.378 ms  34.911 ms  35.468 ms
15  c321.f.de.plusline.net (82.98.98.10)  37.567 ms  39.872 ms  41.826 ms
16  * * *
17  * * *
18  * * *
19  * * *
jelv
Fixes: 10
Mine completes - and looking at the times it's very easy to go to Hell:
C:\Users\John>tracert hell.co.uk
  1    <1 ms    1 ms    <1 ms  tg582 [192.168.1.254]
  2    22 ms    21 ms    20 ms  lo0-central10.pcl-ag03.plus.net [195.166.128.184]
  3    20 ms    20 ms    20 ms  link-b-central10.pcl-gw02.plus.net [212.159.2.170]
  4    20 ms    20 ms    20 ms  xe-10-2-0.pcl-cr02.plus.net [212.159.0.202]
  5    24 ms    21 ms    20 ms  ae2.pcl-cr01.plus.net [195.166.129.6]
  6    20 ms    20 ms    19 ms  ae1.ptw-cr01.plus.net [195.166.129.0]
  7    21 ms    20 ms    39 ms  te-4-2.car5.London1.Level3.net [217.163.45.249]
  8    30 ms    30 ms    31 ms  ae-52-52.csw2.London1.Level3.net [4.69.139.120]
  9    30 ms    30 ms    30 ms  ae-56-221.ebr2.London1.Level3.net [4.69.153.129]
10    31 ms    29 ms    30 ms  ae-22-22.ebr2.Frankfurt1.Level3.net [4.69.148.190]
11    35 ms    30 ms    29 ms  ae-62-62.csw1.Frankfurt1.Level3.net [4.69.140.18]
12    *      31 ms    29 ms  ae-1-60.edge4.Frankfurt1.Level3.net [4.69.154.8]
13    31 ms    31 ms    31 ms  te2-2.c102.f.de.plusline.net [212.162.24.58]
14    30 ms    30 ms    29 ms  82.98.102.13
15    31 ms    30 ms    31 ms  c321.f.de.plusline.net [82.98.98.10]
16    30 ms    30 ms    31 ms  82.98.92.146
17    30 ms    31 ms    31 ms  gw-dist-pl-a.fhe3rz.net [91.195.240.2]
18    30 ms    30 ms    30 ms  www166.sedoparking.com [82.98.86.166]
Trace complete.
AndyH
Your not running any services/programs in the background are you?
Can you post your router stats (assuming you're on ADSL)?
jelv
Fixes: 10
I'm on 20CN so those times are absolutely perfect.
ejs
Aspiring Hero
Fixes: 25
Quote from: vilefoxdemonofdoom
Quote from: jelv
The difference between getting a response from this destination or not is probably (again) due to it not responding to UDP packets (Linux traceroute default), but the destination does respond to ICMP packets from Windows tracert.
Some of the traceroutes posted by Yaroze look strange since they can have very high latency from intermediate hops, but not necessarily such high latency for the final destination.
Yaroze
Quote from: AndyH
No services / programs are running in the background.
Operational Mode: ADSL2+
Upstream: 444
Downstream : 5963
SNR Margin(Upstream): 28.1
SNR Margin(Downstream): 15.3
Line Attenuation(Upstream): 21.4
Line Attenuation(Downstream) : 35.0
Router: Billion 7800n
