Fault on line 111128987 - repeated no shows, how to proceed?
- Feedback
- Plusnet Feedback
- Fault on line 111128987 - repeated no shows, how t...
28-09-2015 11:42 AM
I raised the above ticket on the 18th, have since had 3 no shows for openreach engineers, all plusnet seem to be able to do is rebook, which clearly isn't working if they just don't show up. I don't know what to do to actually get someone to show up & fix this?
Rob
Re: Fault on line 111128987 - repeated no shows, how to proceed?
28-09-2015 1:50 PM
A warm welcome to the forums.
So sad to hear of your poor experience at the hands of BTOR who supply and maintain all of the wires between the exchange and premises for all users other than those with Virgin media. Unfortunately neither PlusNet nor any other ISP has direct control over BTOR resources. Rebooking is about all they can do for you, though given that you've had 3 no shows, you should be eligible for an expedited visit at BTOR's expense and also ask about no-show compensation.
Kevin
28-09-2015 2:31 PM
28-09-2015 4:45 PM
28-09-2015 4:52 PM
Under Ofcom rules, LLU operators have to have a better (default) level of service than that offered to BTw WBC ISPs.
Under Ofcom rules, BT Retail are not supposed to receive preferential service from BTw / BTOR, however empirical evidence / experience suggests that the playing field is not unbiased.
Due to the sceptre of No Fault Found charges, it has to be said that PlusNet are fairly strict at eliminating EU domain matters before passing over to BTOR ... and due to the volumes of issues that can take longer than is ideal.
29-09-2015 8:47 AM
Quote from: Townman Due to the sceptre of No Fault Found charges, it has to be said that PlusNet are fairly strict at eliminating EU domain matters before passing over to BTOR ... and due to the volumes of issues that can take longer than is ideal.
I don't think that's really the issue. I was referring to the additional delay for Plusnet customers after Plusnet have decided that OR attendance is required. Nothing's being done by Plusnet during that time.
In addition, I see no sign that Plusnet take any more trouble than other ISPs to eliminate customer faults prior to engaging OR. Very much the reverse in my experience.
Do Plusnet have an actual escalation procedure that Rob can invoke?
29-09-2015 10:20 AM
From what I have been able to deduce from my own experience and questioning, under normal process, it's about 2 months before esclation routes are open for ISPs to use on line installs. The end user writing to the CEO of BTOR will open doors for the ISP but might still not deliver a timely service.
There is supposed to be a level playing field service delivery from BTOR, however I am far from convinced that they are doing that. LLU operators seem to get priority. I suspect that BT Retail are getting some under the counter favours ... and then to be sure that there is no appearance of in-house favour PlusNET get what's left.
29-09-2015 6:08 PM
Sorry to bring humour in, but I couldn't resist.
Quote from: Townman ...
29-09-2015 6:56 PM
30-09-2015 2:49 PM
Quote from: ejs I don't think we can be sure that Plusnet even booked the engineer appointments correctly these days. Are we going to bother to find out what happened here, or should we just get on with criticising Openreach instead?
Exactly. Plusnet should be able to book the appointment, online, while the customer's waiting. Their link into Openreach should give them online access to the calendar so the first suitable appointment can be agreed between them and the end user right at that time. Other ISPs do this. Instead what Plusnet seem to do is to tell the customer that OR will be booked, but what they do after that is anyone's guess. Do they make an appointment and just not tell the customer? Or pass the instruction to OR without asking when they'll be attending? My first hand experience all they told me was an expected completion date of 10 days after the decision to send OR, no further update from Plusnet, just a phone call from the OR engineer once he turned up.
Plusnet's process needs a lot of work. At the moment all they seem prepared to do is to blame OR or BTW for any issue of any sort.
01-10-2015 11:14 AM
Took far longer than it should have done to get sorted & the relationship between ISP's & Openreach is clearly broken if appointments can just be missed & no-one notifies anyone.
01-10-2015 11:31 AM
- Feedback
- Plusnet Feedback
