Failed Direct Debit payment set-up
- Feedback
- Plusnet Feedback
- Failed Direct Debit payment set-up
04-03-2009 9:01 PM
However it isn't. I now get the same message my account is restricted. I said they can take the payment from my credit card (details of which they have) until its fixed but this was not done. The account is still restricted.
I would set up the direct debit directly with my bank myself if they would give me their account details and whatever else is required but they haven't done so. All we seem to do is go around in circles that they can't debit my account and I can't get them to tell me what I need to do precisely. As I said, they have my correct account details for direct debit and my credit card details. What else can I do?
Re: Failed Direct Debit payment set-up
04-03-2009 9:20 PM
If the DD is live on the account then the usual problem is that the company is claiming under a different Originator's Identification Number (OIN) than the one the DD was set up under. The bank should be able to advise what the OIN on the DD is.
I may be able to make other suggestion if you post what the actual problem was with regard to the DD submission.
[Edit: corrected error in terminology used on DDs]
04-03-2009 10:02 PM
If you want to pay by DD later add the details again after this payment has gone through on the CC.
HTH. If not post back here, I sure someone from PN can sort it.
04-03-2009 10:05 PM
Inspection shows we submitted the Direct Debit mandate, the bank responded around 7 days later (normally) that the mandate had been accepted.
However three attempts to issues transactions against the mandate have all been returned by your own bank as "No mandate exists".
Ideally, I would recomend at the least setting up the mandate online again on our portal under account details. However I even more strongly suggest contact with the bank to investigate why they have declined the three payments on the valid mandate they authorised.
Otherwise no matter what steps we take, this only risks continuing.
05-03-2009 6:48 AM
Was the DD set up by the Bank through 'paper' notification or electronically by Plusnet?
From my own experience this may go round in circles for a while as both the company and bank claim that both sides of the DD are in order. When you speak to the bank ask them for the following information which you should then relay to Plusnet:
Is the DD to Plusnet set up?
What Originator's Identification Number (OIN) as been used on the DD?
When was it set up?
Is their a start date?
What reference as been used?
and last but not least, which account as it been set up on? (most important if you have more than one account that accepts DDs)
Note a company can have more than one OIN and if one digit is incorrectly entered in the OIN field then the DD will show a completely different company name. This latter error is more associated with the bank inputting the DD details manually. The former is what leads to the company claiming under the wrong OIN.
05-03-2009 8:27 AM
Being armed with this information I feel I can now make some progress. At the very least I can challenge my bank regarding the OIN and whether it matches the details for Plusnet.
Thanks for the suggestion to resubmit the DD via my account details. I did do that a number of days ago before posting on this forum but it seems not to have worked (admittedly less slightly less than 7 days ago).
It would have been helpful to have a FAQ page on this issue but I am grateful for the assistance on this forum. Perhaps something for Plusnet to consider in the future or, does the problem not occur very frequently?
I will do what has been suggested and hopefully this can be resolved fairly quickly.
05-03-2009 9:01 AM
My bank claim they have never received any DD instruction from Plusnet.
Just to be sure I have again entered my bank account details in the DD section of My Account and will wait to see what happens.
05-03-2009 9:09 AM
Phil
05-03-2009 10:41 AM
Unless I'm looking at the wrong account, you've had an active DDI since January 28th and there's no record of subsequent requests of you trying to add a new one.
05-03-2009 3:29 PM
I'd PM James with you PN account info. to be sure he's looking at the right account.
05-03-2009 10:52 PM
Thanks for the insight into DD terminology & operation.
I've made use of it already
06-03-2009 6:50 AM
Quote from: sigma359 .....My bank claim they have never received any DD instruction from Plusnet. ....
It may be worth asking your bank exactly what direct debits are set up on your account to see if there are any that you don't recognise
[quote=P Richardson ]Inspection shows we submitted the Direct Debit mandate, the bank responded around 7 days later (normally) that the mandate had been accepted.
because normally the notification of the beneficiary that a mandate is set up is automatic. Plusnet trade under several different names, but your bank won't normally recognise the other names Plusnet uses unless you advise them of what to look for. Even if the DD was canceled by mistake it would still show up on your account unless it is purged and the beneficiary would be notified of the cancellation. It is unusual for a DD to be purged unless the mandate is a duplicate.
06-03-2009 10:09 PM
17-03-2009 2:57 PM
Quote from: Jameseh Hmm.
Jamesh, Thanks for looking into this for me. and thanks to the other contributors.
I have now updated but the DDI (with the same account details) is still being reported by Plusnet as failed. My account details work for me when I pay into the account - which indicates the details are correct.
I use e-Banking and have not seen on my account on the bank web-site or having telephoned the bank been advised by them that any instruction has been received from Plusnet (or anyone else) recently. So the problem isn't going away yet....
17-03-2009 3:45 PM
If it is still restricted I'd be making some pretty strong demands.
