FTTP Welcome Guide - Link Borked
archerry
Fixes: 4
Taken the plunge to upgrade to FTTP and have an installation date.
The link given in the email: https://booklet.plus.net/welcome-to-full_fibre is borked.
From a quick web search, this is not the first time.
A part screen shot is attached:
Regards,
Alistair
8 REPLIES 8
Anunnaki
Re: FTTP Welcome Guide - Link Borked
When I follow that link I get this -
archerry
Fixes: 4
@Anunnaki
Indeed, so did I.
But if you accept the risk and continue you will find what I posted.
The page has not been maintained correctly.
A PN staff member needs to feed this back to the appropriate team.
Regards,
Alistair
MatthewWheeler
Fixes: 503
Hi @archerry
Thanks for flagging.
I've raised this to the right team to look into
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
Fixes: 254
Hi Matthew,
Can you get the root of the web service checked out as well please.
http://booklet.plus.net delivers...
Welcome to nginx!
If you see this page, the nginx web server is successfully installed and working. Further configuration is required.
For online documentation and support please refer to nginx.org.
Commercial support is available at nginx.com.
Thank you for using nginx.
Note: No HTTPS nor subdirectory.
Mav
Fixes: 518
I now get the same error as the OP but the first time I saw a message about the certificate having expired.
Forum Moderator and Customer
archerry
Fixes: 4
Three weeks since I raised this topic and the link still shows the same page.
Is it ever going to be fixed?
I now have a functional FTTP connection but I would like to know what advice is given in the guide.
Regards,
Alistair
Fixes: 254
@NickBS
Is this one you can pipe clean please?
matthewleggott
Same issue here, on a recent order, link still doesn't work.
