E-Mail presentation
DaveB29
E-Mail presentation
Just moved from BT Total Broadband and am concerned to find that the e-mail page does not have a Spellckecker,nor can one  change the Format (Font, Colour. etc)
Is this just normal or something thAT pLUS mAIL COULD PROVIDE?
4 REPLIES 4
Oldjim
Resting Legend
Fixes: 63
Re: E-Mail presentation
If you are using webmail you need to change the Options Display Preferences to Show HTML version by default.
If you want a spell checker use Firefox with British/English Dictionary
DaveB29
Thank you for your reply.
It really does nothing to treat my original query, though
orbrey
I don't think there's a plugin available for the webmail platform I'm afraid. As Jim says, if you use webmail the best bet would be to get a spell checker plugin for whichever browser you use to access it - you can install the British English dictionary here.
As for the formatting, again that's down to the settings as Jim says - if you change the Display preferences in your options to Show HTML version by default when you compose your message you'll be able to apply formatting.
bobpullen
Fixes: 331
There is a spell-checker plugin for Squirrel.
Not sure what build we're running but SquirrelSpell is packaged natively with version 1.2.0 and above so it might just be a case of us enabling it at this side.
In the meantime, I've dropped you a private message Dave with another possible solution.
