Duplication in Email sent
thebug
Why when I send an email does it duplicate my username e.g xxxxxx.xxxxxx.@plus.
1 REPLY
Fixes: 71
Re: Duplication in Email sent
It uses whatever you specify as your "from" address in your email client. If you are using webmail you might need to modify the entry you will find as E-mail Address on the Options->Personal Information page. If you make any changes remember to scroll down to the bottom of the page and click Submit.
David
