Dramatic speed drop on an evening
mikewihte
Just noticed the last couple of days , my speed drops from 7000 during the day to around 300-600 on an evening , makes it really difficult to do anything other than browsing . Just wondering if there was any reason for this
4 REPLIES 4
Oldjim
Resting Legend
Fixes: 63
Re: Dramatic speed drop on an evening
What is the status of your exchange - it might be due to local congestion http://usertools.plus.net/exchanges/
Can you monitor the errors during the evening as compared to the day time as large numbers of errors can really wreck your speed tests
mikewihte
Exchange seems fine no congestion , howdo you check for errors ?
Oldjim
Resting Legend
Fixes: 63
depends on the router - there should be something in the detailed stats - I use Routerstats with mine
The other thing is to check how low your noise margin goes - if mine goes below about 2.5 dB the speed is clobbered
jojopillo
Hi mikewhite,
Firstly I would check here for anything obvious, also, If you can run some BT speed tests during these times before raising a fault if none of the above.
Jojo Smiley
