DNS servers failing
nigel1971
Re: DNS servers failing
Open DNS which i was on before stopped working also and still not now, had to change to google's dns as a temp fix.
Glix
Starting to look better now.
30 mins ago:
Tracing route to edge-star-shv-01-iad3.facebook.com [31.13.69.197]
over a maximum of 30 hops:
 1    <1 ms    <1 ms    <1 ms  RT-AC56U-9348 [192.168.0.1]
 2    17 ms    16 ms    16 ms  lo0.12.central12.pcl-bng01.plus.net [195.166.130
.140]
 3    16 ms    16 ms    16 ms  irb.12.pcl-cr02.plus.net [84.93.249.114]
 4    17 ms    17 ms    17 ms  195.99.126.98
 5    17 ms    17 ms    17 ms  core3-te0-19-0-20.faraday.ukcore.bt.net [109.159
.249.157]
 6    17 ms    17 ms    17 ms  peer2-et-3-3-0.faraday.ukcore.bt.net [62.6.201.1
65]
 7     *        *        *     Request timed out.
 8     *        *        *     Request timed out.
 9     *        *        *     Request timed out.
10     *        *        *     Request timed out.
11     *        *        *     Request timed out.
12     *        *        *     Request timed out.
13  ^C
now:
 2    16 ms    16 ms    16 ms  lo0.12.central12.pcl-bng01.plus.net [195.166.130
.140]
 3    17 ms    16 ms    17 ms  irb.12.pcl-cr02.plus.net [84.93.249.114]
 4    17 ms    18 ms    17 ms  195.99.126.98
.249.157]
 6    17 ms    16 ms    17 ms  peer2-et-3-3-0.faraday.ukcore.bt.net [62.6.201.1
65]
 7    17 ms    17 ms    17 ms  213.137.183.36
 8    92 ms    92 ms    92 ms  ixp1-xe-1-0-0-0.us-ash.eu.bt.net [166.49.208.53]
10    93 ms    91 ms    92 ms  psw01a.iad3.tfbnw.net [204.15.23.162]
11    92 ms    92 ms    91 ms  msw1ac.01.iad3.tfbnw.net [204.15.23.62]
12    91 ms    91 ms    91 ms  edge-star-shv-01-iad3.facebook.com [31.13.69.197
Trace complete.
Good job to those fixing it behind the scenes.
WWWombat
Quote from: nursemorph
Quote from: Kremmen
All starting to come back this end  Smiley
Yep...same here....have tried 10 different sites that were inaccessible 10 minutes ago and they all load fine and quickly
Same here. www.gov.uk and uk.yahoo.com have become available.
Seems like things are a little fluid...
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
JASLincs
All back to normal here.  Well done to whomever sorted this out.
rongtw
Fixes: 12
thing is ,,, if 24hr support was here it would have been fixed AGES  ago  Cry Cry  NOT  good PN
nigel1971
Facebook Loads but very slow.
martinu
Plusnet support
Can I urge you (as I often do when you have server problems like the one you have at the moment) to list the fault on the Service Status page as soon as you become aware of it, *even before you've investigated and identified the cause*.
This would save a lot of support calls. Service status was the first thing I checked when I discovered the problem at 08:15 this morning, and when I saw that there were no known problems, started to investigate whether it was a problem at my end (eg reboot router, try a spare router, try pinging by IP address as opposed to by URL).
That was when portal.plus.net was still working fine - I realise that you've now lost the whole of portal.plus.net including the service status page.
Good luck in getting everything back!
cobcottageonlin
DNS not working for me; switched to Google (DNS) as of 09:15.
tijara33
Fixes: 6
I've changed my DNS to 8.8.8.8 in my Asus router & all is now OK. Thanks for the work arounds posted on here. PN have really messed (too polite to use the word I really want to write) up this time.
Why still no announcement?
nozzer
Quote from: MattyC
I've just posted in the announcements thread. I've given it a title a little more understandable for anyone visiting this forum for the first time for the purpose of the outage. I'll provide updates ASAP.
Matty
That would be good if the status page was available! The Portal seems to be completely dead!
EDIT: As you were. Misread "announcements"!
MattyC
Fixes: 46
Just got a service status up. The issues were impacting our ability to get the status up.
Havel
Quote from: MattyC
Where is the service status?
racquel
First the support site down for over a week recently, and now this MAJOR outage.
Question: Have you had an expensive new senior support manager/consultant in lately? Perhaps using phrases like "customer satisfaction metrics going forward"?
Just guessing...
nursemorph
Quote from: MattyC
The issues are impacting our ability to read service status messages as the main site is not loading
rongtw
Fixes: 12
YES !!
The server at portal.plus.net is taking too long to respond.
    The site could be temporarily unavailable or too busy. Try again in a few moments.
    If you are unable to load any pages, check your computer's network connection.
    If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web.
