DNS servers failing
- Feedback
- Plusnet Feedback
- Re: DNS servers failing
10-09-2015 7:39 AM
DNS servers down all including DNS down 212.159.6.9 also second ending with 10 also 212.159.13.49also second DNS ending in 50.Cant report 24/7 service stopped.
PlusNet are getting worse as they grow and I have seen this since being with this service.
Like they are too big for their boots attitude, once the company get's to large the residential customers become just another number or a non caring approach seems to have appeared from PlusNet.
The PlusNet attitudes have change from
''We will do you proud''----- To --- ''We will not give a care in the World as we have so many customers now losing a few is no problem to us!''
I have had to change all settings in router and Xbox as well as for DNS using OpenDNS.
This service is not good enough! Many users use their net after 10pm or does PlusNet not understand that?
Going to the non 24/7 service has made no difference to the waiting times even after a promise of faster response times by PlusNet after Leeds centre opened!
Start neglecting your residential customers PlusNet and you will be losing them in the 1000s!
Your systems should be monitoring drops of DNS and some form of after 10pm reporting and management service should be implemented ASAP
You Have Not Done Us Proud!
Re: Some sites load, others don't and show ERR-NAME-RESOLUTION-FAILED
10-09-2015 7:40 AM
10-09-2015 7:43 AM
...after being led up the garden path for a while by http://www.asus.com/uk/support/FAQ/1010145 - beta firmware made no difference, but their secondary workaround of changing DNS worked...I can't actually tell how old that FAQ is - no date, thanks Asus.
Anyway, so it looks like it's a plus.net issue seems to be the consensus here...quick note to those having trouble with changing the DNS settings - you may need to renew your DHCP lease on your PC/device to get that to actually take...my usual 16 or so daily websites all come up fine with Google 8.8.8.8
I did briefly try explicitly setting DNS to 212.159.6.9 (the primary server DHCP gives my router) but that didn't seem to work...
Interestingly when all was dead before I tried anything the ping tool on my router was able to resolve www.google.co.uk and ping it OK - don't know if the Asus firmware ignores the DNS settings from the ISP and just uses Google or something...
Anyway, good luck all - I'm off to work - hoping this will be resolved by the time I get back.
On a related note, this may all be my fault - I was saying only the other day to one of the guys at work how reliable my ISP was...DOH!
Cheers,
Greg
10-09-2015 7:48 AM
10-09-2015 7:50 AM
That honesty and transparency on the service status page used to be the reason I recommended PlusNet to people....
10-09-2015 7:50 AM
Apologies for the lack of any official service notification.
10-09-2015 7:51 AM
Some traces at http://community.plus.net/forum/index.php/topic,143620.msg1266365.html#msg1266365
10-09-2015 7:52 AM
10-09-2015 7:52 AM
10-09-2015 7:52 AM
10-09-2015 7:56 AM
10-09-2015 7:58 AM
google.co.uk gets a DNS fail, but google.com is fine
yahoo.co.uk is the same
theregister.com resolves, but can't connect (I think the server is UK based)
plus.net works, luckily, but you can't report faults (hurrah! Need an emergency button on that page)
10-09-2015 7:59 AM
10-09-2015 8:00 AM
10-09-2015 8:01 AM
