Curiosity about speeds
sixthprawn
Re: Curiosity about speeds
Small improvement Smiley
adamwalker
Fixes: 223
Good to hear, looks like our faults team are assuming all is well. Let me know if we need to give this any more attention for you.
 Adam Walker
sixthprawn
Not to happy to pay for a month of rubbish internet, do i have to start a ticket regarding that?
sixthprawn
Also. to save a phonecall, am i still on interleaved?
sixthprawn
As i'm obviously a bit of a novice at this stuff, are my errors a bit high?  And should my sn have gone down more?
Link Information
Uptime: 4 days, 21:16:47
DSL Type: G.992.3 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 888 / 2,616
Bandwidth (Up/Down) [kbps/kbps]: 440 / 2,872
Data Transferred (Sent/Received) [MB/GB]: 733.55 / 4.90
Output Power (Up/Down) [dBm]: 12.5 / 18.0
Line Attenuation (Up/Down) [dB]: 29.0 / 52.5
SN Margin (Up/Down) [dB]: 21.0 / 9.5
Loss of Link (Remote): 0
FEC Errors (Up/Down): 2,695 / 95,785
CRC Errors (Up/Down): 118 / 1,053
HEC Errors (Up/Down): 142 / 10,434
adamwalker
Fixes: 223
Nope I shall look into this and get back to you
Ditto Smiley
 Adam Walker
sixthprawn
Quote from: _Adam_Walker_
orbrey
Hi sixthprawn,
Your line is still interleaved (well it's set to auto, which means it will almost certainly be on). I'd definitely not recommend turning it off with your line as it is though. With regard to the ticket, I've credited off the broadband portion of next month's subscription for you.
Hope that helps,
sixthprawn
Hi matt, thanks for that:)
So, am i stuck with speeds of 2.28 or can this be improved?
jojopillo
Hi sixthprawn,
I'm wondering whether the attenuation we're seeing is correct. If it was, then things look about right. If not then we could get more. Can you tell me how your kit is set up, what router you're using etc.
Jojo Smiley
sixthprawn
I'm using a Thompson tg585.  here are latest stats for it
Link Information
Uptime: 7 days, 1:44:45
Maximum Bandwidth (Up/Down) [kbps/kbps]: 888 / 2,728
Data Transferred (Sent/Received) [GB/GB]: 1.02 / 7.55
SN Margin (Up/Down) [dB]: 20.5 / 10.0
FEC Errors (Up/Down): 3,395 / 131,775
CRC Errors (Up/Down): 139 / 1,314
HEC Errors (Up/Down): 175 / 11,898
I was asking as bt wholesale tell me i should be getting around 7 on adsl2+
jojopillo
HI sixthprawn,
Thanks, I also need to know how your equipment is set up.
Jojo Smiley
sixthprawn
Two pc's both on ethernet. Direct from main socket with no extensions.
jojopillo
When you say the main socket, do you mean the test socket? If so, are you able to try a different filter and different router?
sixthprawn
I have tried both the main and test, and various routers.
