Connection details page: DNS servers
jelv
Fixes: 10
Any reason why https://portal.plus.net/my.html?s=0&action=refresh_browser doesn't say
Optional tertiary DNS server  212.159.6.9 or 212.159.6.10
At that the moment the page doesn't give the last DNS IP.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
7 REPLIES 7
w23
Fixes: 4
Re: Connection details page: DNS servers
Mine shows:
Primary DNS Server  212.159.13.49
Secondary DNS Server  212.159.13.50
so not missing for everyone.
Call me 'w23'
Fixes: 1,495
I get the optional one showing too
jelv
Fixes: 10
Quote from: walker23
Mine shows:
Where's 212.159.6.10? That's the point I was making.
w23
Fixes: 4
Sorry, misinterpreted your OP, though you weren't seeing ANY optional tertiary address.
Maybe the clue is in the word 'tertiary', if they showed all of them they'd need to change that word  Wink
Do they assume that you'd never need more than three?
Does this mean that 212.159.6.10 is likely to be under-utilised (I don't think this is the case as this tends to be the one my router (set on Auto) shows as 'currently used for standard queries')
Call me 'w23'
prichardson
To be honest, I don't specifically know why we have the tertiary listed at all.
All four IPs are in a nut shell, all the same these days. The cDNS systems have been setup in a way that we never changed IPs and thus, did not need to change customer habits.
We now operate in excess of 4 servers, which are load balanced. When using our 4 core cDNS servers IPs, you will be distributed across the servers for the site at which your DSL session terminates.
It is still recommended you use cDNS server IPs in pairs though (212.159.6.9 & 212.159.6.10, 212.159.13.49 & 212.159.13.50).
So as above, I don't know why we list the 3rd, as there is no performance benefit.
Anotherone
Champion
Fixes: 21
212.159.6.9 & 10  I always thought were the ones to use for BB, and the other two for Dial-up! And 212.159.6.9 & 10 are the ones that are retrieved automatically on my 20CN connection.
As far as I'm concerned, if they are all the same they should all be listed.
jelv
Fixes: 10
I can see the logic of only giving two as they all go to the same servers anyway, and giving all four makes sense. But listing three... !
