Can't Login
MrToast
Can't Login
I can't log in to the portal with either of my two accounts..... so I can't raise a ticket to tell you (I could call of course)
Am  alone?
5 REPLIES 5
Pettitto
Fixes: 5
Re: Can't Login
Nope you're not alone. Our Internal systems are down at the moment.
Should have it sorted shortly. Sorry about this.
Edit: You should be able to log in now.
mike360
Re: Can't Login
yeah same here but i can log into web mail weird  Huh
mike360
Re: Can't Login
now i can. cheers
MrToast
Re: Can't Login
Thanks Chris.
Yes I'm in now.... that was quick! Smiley
Pettitto
Fixes: 5
Re: Can't Login
Smiley
