Can I add the Pro add on when changing from "pro"
- Feedback
- Plusnet Feedback
- Can I add the Pro add on when changing from "pro"
23-11-2011 10:57 PM
What I dont want to do is select mynew product, "extra", which wont take efect until my next billing run, and then have to wait aother cycle to get the pro added.
Any ideas?
Re: Can I add the Pro add on when changing from "pro"
23-11-2011 11:41 PM
Add pro through "Add-Ons" (may take a few hours to appear dependant on how well the system takes the swap over)
You can do this "on the fly" (e.g. it gets added Pro-Rata for that month) so you'll get pro as soon as you 'add' it to your account.
Regards
24-11-2011 10:04 AM
25-11-2011 5:33 PM
29-11-2011 2:09 PM
29-11-2011 2:18 PM
We have two add ons, the Pro add on which is £5.00 per month and static IP which is a one off charge of £5.00
Jojo
29-11-2011 2:41 PM
29-11-2011 2:52 PM
Would wouldn't charge you to change package, only what it costs for the new package.
Jojo
29-11-2011 3:02 PM
Quote from: Joanne HI twitchy14,
Jojo
Max Premium?
30-11-2011 3:30 PM
Quote from: jelv Max Premium?
Not available for all customers and not on the add on page of the portal, good try though
- Feedback
- Plusnet Feedback
