Can I add the Pro add on when changing from "pro"
chesterfield
At present Im on a legacy product of "pro" - which is a 20GB limit but everything at line speed.  Id like to move to the extra product with the "plusnet pro" add on.  However during the change my product process, I cant see anywhere to select this add on.
What I dont want to do is select mynew product, "extra", which wont take efect until my next billing run, and then have to wait aother cycle to get the pro added.
Any ideas?
9 REPLIES 9
matt_2k34
Re: Can I add the Pro add on when changing from "pro"
You change to extra, which will occur on your next billing date.
Add pro through "Add-Ons" (may take a few hours to appear dependant on how well the system takes the swap over)
You can do this "on the fly" (e.g. it gets added Pro-Rata for that month) so you'll get pro as soon as you 'add' it to your account.
Regards
chesterfield
Ah, thanks.  Ill wait for the switch over to Extra early Dec and then get the pro added as soon as the switch has completed.
adamwalker
Fixes: 221
Yes, just to confirm, changing account types are done on the next billing date and add-ons can be added on at any point.
 Adam Walker
twitchy14
Hi is there a charge for extra services, ad ons, meaning for transferring to one.
jojopillo
HI twitchy14,
We have two add ons, the Pro add on which is £5.00 per month and static IP which is a one off charge of £5.00
Jojo Smiley
twitchy14
hi thanks for info, but is there a charge for upgrading from origonal logb signed up to the 60gb, is there a l5pound charge for transfer.
jojopillo
Hi twitchy14,
Would wouldn't charge you to change package, only what it costs for the new package.
Jojo Smiley
jelv
Fixes: 10
Quote from: Joanne
HI twitchy14,
Jojo Smiley
Max Premium?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
jojopillo
Quote from: jelv
Max Premium?
Not available for all customers and not on the add on page of the portal, good try though Wink
