Brand New Member and I'm Worried...
- Feedback
- Plusnet Feedback
- Re: Brand New Member and I'm Worried...
01-02-2010 4:23 PM
tried calling plusnet on 08451400200 number but got message that calls were taking 10 minutes to answer.YET, plusnet 'stats' indicate that calls are currently being answered in less than a minute and they only have 1 call waiting?!!
Please tell me I made the right decision in moving to Plusnet....!!
01-02-2010 5:36 PM
01-02-2010 5:38 PM
Quote Yesterday got stuck on setting up email
If you'd like to explain your problem then I'm sure the people on here will try to help you.
Oh, and welcome to the forums.
01-02-2010 5:48 PM
When I set up the initial email address yesterday I did not do my homework very well and the resulting 'primary' email address is not what I want. My rather simple question is: can I change my primary email address now it's registered.
I would like to have my nickname@surname.plus etc.
I appreciate that I can have additional email addresses and these are re-directed.
01-02-2010 5:53 PM
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
01-02-2010 5:53 PM
Before the @ you can have anything you want
01-02-2010 6:18 PM
Does that mean that I can change the primary email address - at least the first part ie newname@username.plusnet?
01-02-2010 6:43 PM
This is the main spot for adding and removing email addresses https://portal.plus.net/my.html?action=myemail&s=1&redirected=yes&?membermenu=emailsettings
This is worth a read http://www.plus.net/support/email/newemail.shtml?supporta=addaddress
You can change the contact email address here https://portal.plus.net/my.html?action=view_details&s=0 but ensure you have setup the email address first and that it has been activated. I think it takes about half an hour
01-02-2010 6:52 PM
Quote Does that mean that I can change the primary email address
If that's what I think you mean then yes. You can rename your default mailbox see section 2 of this https://portal.plus.net/support/email/mmm_overview.shtml.
But you can also create additional mailboxes, they are not just redirects they are completely separate mailboxes, so why not just create an additional mailbox for 'nickname'. You can also redirect the 'catch all' mailbox to any of your mailboxes.
01-02-2010 7:29 PM
Many thanks to you both. I'm going to give your suggestions a try after getting some nourishment.
01-02-2010 7:33 PM
01-02-2010 7:55 PM
01-02-2010 7:59 PM
01-02-2010 8:06 PM
Quote The one part you can't change is the part after the @ which is your main username.
01-02-2010 8:13 PM
