Because I am a bit (lot) nosey
- Feedback
- Plusnet Feedback
- Re: Because I am a bit (lot) nosey
17-08-2012 5:03 PM
17-08-2012 7:48 PM
But for those who do experience problems it can still take much longer than expected. BT Openreach can still be quite inept if you get one of 'bodgejobsworth' types - getting much less of a problem though. The current 'hotshot' in this area is a young female technician of about 25
Maurice
18-08-2012 9:02 AM
For example, my Mum (91) lives in a town and is quite near to the exchange. She was changed to 21Cn and ADSL2 and has not noticed. It all just went smoothly and delivered a higher speed to her without any problems. (They even have fibre to the cabinet available!)
I live in a village some 3km from the exchange and was recently changed over. I get a faster speed when it works but interference causes huge problems and long periods when I am connected but the connection is useless - huge numbers of CRC errors. Its being investigated but BT are struggling. It is not an easy problem to solve.
I think BT got carried away with its technology and have implemented a system that is fine in a town (generally) but over longer lines does not have the resilience it should have. There is no compromise option that can give me some improvement in speeds over ADSL1 but also cope with the problems of long lines. Its all or nothing.
Yes, I reported the fault. Yes it is being worked on. But the percentage of people complaining will be low because the percentage living in villages is low.
18-08-2012 12:28 PM
i want to moane!!!!!! but i cant ,, haaaa
18-08-2012 3:20 PM
Like EnglishMohican, I have a long line, but I live in a town. Initially I was connected via ADSL2, but got punished by DLM as the line had been very unstable. After several visits from OR engineers and all possible solutions, which did not succeed, PN decided to connect me via 20CN as the DLM will not be very harsh. Some you may remember my coming on to this forum in the past with Adam Walker owning the Isuue I had. You have not heard from me since switch over to 20CN as I haven't had any cause to.
Recently, I was switched over to 21CN with ADSL1 (Max). Switch over went smoothly and noticed an improvement in my speed as compared with what I got under 20CN. Line is still very stable for last 230 hours (Nearly 10 days).
So, I would say well done PN (and, dare I say, BT).
I would say, OldJim, you may find many PN customers like me.
Many Regards,
Chandu.
18-08-2012 10:16 PM
23-08-2012 2:50 PM
I don't have the consumer numbers to hand, let me do some digging.
M
23-08-2012 2:59 PM
The fault rate is calculated by dividing the monthly fault volumes by the average working system size, multiplied by 365 and then divided by 28 or 35 depending on whether it’s a 4 or 5 week month.
20CN: 0.092
21CN: 0.09
This is current data from this weeks reporting.
The maths geniuses out there (Oldjim you can crunch the data) should be able to get the gist of that.
Volumes are very low as you can see.
Mark
23-08-2012 3:05 PM
Were you intending to stuff these figures up one of the troll professor973's orifices?
23-08-2012 4:38 PM
Translating how I understand it
Number of faults per month = N
Number of users = Y
Number of days in a month = Z
Hence total number of faults per day = N / Z
Number of faults per year = N / Z x 365 = F
Number of faults per user per year = F / Y
and you say that is 0.09 on 21CN
That means that on average 1 user in 11 will have a fault in a year unless you missed a % out somewhere
23-08-2012 5:14 PM
The problem really seems to me to be that this figure assumes an homogenous distribution of faults across all of Plusnet's customers. As I said further up the thread, I fear that some customers are more liable to BT type faults than others. People on long, overhead lines out in the sticks are much more likely to have a BT type failure than those who live in a town (there will be exceptions that prove this rule !).
The country cousin also receives a poorer service in the sense that even when the line is working, it will run much more slowly than many town based lines. This is likely to be an accepted consequence of living in idyllic country but could be considered a failure even though with BT's T&C it will not be a fault.
This figure is really not much more than a simple (management grade) kpi virtually designed to make things look "under control"
23-08-2012 5:36 PM
Multiply that up for the other major ISP's and it is no wonder BT Openreach are struggling
23-08-2012 6:33 PM
The other side of the coin is just what provision Openreach make to handle faults - essentially, how many engineers do they have? They are only going to struggle if the resource is inadequate. Even if 45000 is correct and all the other ISPs are worse, BT is a big company with huge resources targeted at these faults.
45000 faults is roughly 200 faults per (working) day, assume that an engineer clears 7 faults per day - (one per hour, optimistic?) then we need 30 engineers for Plusnet faults. That's not many.
I am more interested in discovering whether there are more faults being reported since the adsl2 rollout and the ftc rollout started. The forums seem to have a fair few problems related to those two. Is it more than was originally forecast/planned for?
03-09-2012 9:34 AM
Quote I am more interested in discovering whether there are more faults being reported since the adsl2 rollout and the ftc rollout started
As per Mark's posts we can look at current fault rates but it might not be possible to look retrospectively at what they were like before those technologies became widespread.
05-09-2012 12:51 PM
For example, different users have different expectations and understanding about what performance they should and are actually getting. If my line trundled along at 1Mbps I'd raise a fault because I know it is capable of far higher (both theoretically and emperically) however someone else may have no idea that anything was wrong and thus wouldn't say a thing thus fall under your radar.
A case in point; I've found it quite fascinating looking at the speed test results for other people in my vicinity using USwitch's Streetstats service. My speed is significantly higher than the majority and regardless of the fact that the discrepency could be down to customer's wiring/equipment/etc - and nothing to the with the provider - it does make me wonder how many of them are aware that they could/should be getting far better connectivity.
Of course, Jim did state he was just wondering what proportion of customers raise faults and thus wasn't necessarilly going to infer anything in particular from that information e.g. as a measure of customer satisfaction of how 'good', for whatever definition of the term, the service provision actually was, or an indication of how many faults there actually are.
Mathew
