Bandwidth Speed Check on Connection Settings Page
pennbank
The bandwidth Speed Check has been showing  Sorry - My Broadband Speed is currently experiencing technical difficulty and may display misleading test results. Thanks for bearing with us while we fix things.
This message has been there for some time now.
Is plusnet going to replace the link with another provider  such as speed test net or similar
2 REPLIES 2
Anotherone
Champion
Fixes: 21
Re: Bandwidth Speed Check on Connection Settings Page
It seems to work ok when not under heavy demand.
adamwalker
Fixes: 223
Yes, it seems to be fine at the moment. Thanks for the heads up though.
 Adam Walker
