BTOR being taken to task
- Feedback
- Plusnet Feedback
- Re: BTOR being taken to task
29-06-2015 10:03 PM
https://corporate.sky.com/media-centre/news-page/2015/sky-reveals-evidence-of-openreach-service-fail...
When can we look forward to PN throwing their hat into the ring and joining Sky in taking their sister company to task publically?
[This is of course a rhetorical question as PN has demonstrated time after time their unwillingness to actually challenge Openreach]
29-06-2015 10:44 PM
Quote Openreach changes the agreed installation date for Sky customers on average around 36,000 times a
month
29-06-2015 10:49 PM
Quote from: pwatson When can we look forward to PN throwing their hat into the ring and joining Sky in taking their sister company to task publically?
Simple answer, never.
Regards
Mike
29-06-2015 10:55 PM
29-06-2015 11:37 PM
30-06-2015 6:26 AM
30-06-2015 9:16 AM
As for the suggestion that Openreach should not be blamed for the faults in their network, who else is to be held responsible? It is their network and excluding exceptional extreme weather issues, proper investment in the last mile network ought to have eliminated the source of the majority of faults. The issue is that whilst there has been investment in the fibre access network, there has been zero investment in the d-side infrastructure. Much of it is 40+ years old.
30-06-2015 9:17 PM
Ironically, the people who often complain I'm twisting their words seem to manage to misinterpret what I was trying to convey. If the total number of faults in a particular year was higher than the previous year, it's not necessarily because Openreach were doing worse, it could have been due to various external factors like the weather or cable theft, which Openreach can't directly control, although I suppose if all the metal telephone wires had been replaced with underground fibre-optic cables to every property, then they would be less susceptible to damage from high winds and also less attractive to cable thieves.
I suppose if Plusnet are going to have adverts with all those customers marching into their offices and demanding better service, then I suppose one might expect Plusnet to be doing the same to their suppliers. Otherwise, the only reason Plusnet might have a higher proportion of satisfied customers than other ISPs will be because all the dissatisfied customers will have left.
There are also a load of stats available from Openreach.
30-06-2015 9:28 PM
Quote from: ejs Otherwise, the only reason Plusnet might have a higher proportion of satisfied customers than other ISPs will be because all the dissatisfied customers will have left.
Well they do seem to be motivating people to consider moving away in a manner not seen before ...
30-06-2015 9:38 PM
There are areas that Openreach has failed on and let customers down on, with ethernet being the prime one. The CEO has openly apologised to customers and they have been weekly briefings about making improvements to the service that is provided.
On WLR/LLU/FTTx, Openreach is meeting all 60 targets set by OFCOM. Have Sky complained to OFCOM that the targets are not stringent enough? Nope. If they were unhappy with the service for so many years, why did they not raise an official complaint with OFCOM?
I also find it strange how Sky have accused Openreach have underinvested in the UK infrastructure - well how do 75% of the country have fibre? No regulator is going to split up a company with a monopoly that is in the middle of a huge capital investment in future broadband access. Would there really be the same level of investment and broadband expansion from a company that it split off from BT? I very much doubt it.
30-06-2015 10:01 PM
Also you seem to think its enough that openreach only has to reach ofcom targets, what happened to the company having pride, they should be aiming for 0% missed appointments, 0% faults etc.
Also how do you know sky have not complained to ofcom? maybe they have and ofcom said tough luck and so decided to go public.
30-06-2015 10:09 PM
- More than 90% of new line installations, which require an Openreach engineer to attend, take 10 calendar days or longer. Almost one in ten installations takes longer than 30 days.
- Openreach changes the agreed installation date for Sky customers on average around 36,000 times a month.
- Openreach misses over 500 appointments each month to install new lines for Sky customers and fails to complete a further 4,000 jobs per month.
It seems that almost every day there's a post on this forum where PN customers are complaining of no-shows for installations/repairs and issues caused by BTOR changing booked dates.
Admittedly the impact of this latter problem is compounded by PN's lack of process for picking up the change and communicating it to their customer (and/or PN's inability to actually place the order in an increasing number of cases) so PN are far from blameless but Sky are highlighting issues that affect the whole industry.
30-06-2015 10:18 PM
30-06-2015 10:19 PM
http://hexus.net/business/news/telcos/84338-sky-calls-ofcom-investigation-uks-broadband-marketplace/
30-06-2015 10:35 PM
Quote from: pwatson - More than 90% of new line installations, which require an Openreach engineer to attend, take 10 calendar days or longer. Almost one in ten installations takes longer than 30 days.
I cannot give you the Sky breakdown, but I can provide this:
Scotland is an issue for new line installations (there is a reason for this...):
Edit: If you read through the Sky report, I think certain things can be pulled to pieces as nothing more than a competitive motive.
