BT ordered to repair most faults 'within two days'
- Feedback
- Plusnet Feedback
- Re: BT ordered to repair most faults 'within two d...
10-07-2014 9:11 AM
OK then. My line problems have been ongoing for over 4 months, and it's been 3 days since my BT Openreach "no show". How they think they can achieve that target when after 3 days I don't even have a new appointment for a new "no show"...
Ticket: 86895764
Re: BT ordered to repair most faults 'within two days'
10-07-2014 9:51 AM
Sorry to hear you've had a missed appointment, I've just taken a look into the raised fault and we seem to show 2 attempted visits on both the 8th and the 9th of July and the engineer has recorded that access to the property was refused. I've returned this back to them to further continue with the fault fix so we should see something back from them soon on how we need to progress the matter.
Please accept our apologies for the this delay, we'll attempt to get you another engineer booked for the dates you outlined on the support ticket and will update it once we have this confirmed.
10-07-2014 9:54 AM
10-07-2014 9:56 AM
Obviously, Plusnet will be asking for this evidence from their suppliers.
10-07-2014 10:18 AM
Out of curiosity & I have never heard of before
Since when does BTOpenreach have to take a pic of your front door ?
Also does this also apply to the Kelly's boys / girls
10-07-2014 10:21 AM
10-07-2014 10:23 AM
Quote If there is no access when you arrive, try to contact the end user on the contact numbers you’ve been given. The only exception to this is when the end user has confirmed during ring ahead that access won’t be provided within the appointment slot. Try all the contact numbers provided if the end user hasn’t answered. This is especially important if you are visiting business premises, where a number of people, including the CP service contact, might have been added to the contact list to make sure that somebody is available. If you don’t make contact, make sure you update your notes, adding the numbers you called and mentioning if you left a message or not – giving the house door colour as the key identifier for premises. If the end user has declined access or there is another reason why you can’t gain access, please make this clear as well. Having this information in our systems helps us when we’re explaining the situation back to the CPs.
Also remember to take a photo of the premises (the front of the house, including the door) If you have a smartphone with a camera, and send the picture via the ‘User no access’ app on your phone. Also leave an A108 card through the post-box. Again, this helps us when we’re explaining what’s happened to CPs. If you can’t leave an A108 make sure you explain why on the notes so we can let the CP know.
10-07-2014 10:25 AM
Edit: predictive text typos corrected!
10-07-2014 10:30 AM
10-07-2014 10:34 AM
I've managed to book and escalate an appointment for you and have updated your support ticket to reflect the full details.
10-07-2014 10:35 AM
And yes, I appreciate it's 80% within 2 days for OpenReach, but when the ISP ticket turnaround is 3 days, then 2 days to fix a fault seems a rather unrealistic target...
10-07-2014 11:03 AM
10-07-2014 11:07 AM
As a pic of your front door is not evidence that they, knocked on the door or rang the bell / buzzer etc
10-07-2014 11:09 AM
Quote from: ReedRichards Openreach may try to fix most faults within a few days and they probably succeed. But last time I looked they offer no time commitment whatsoever in those cases where they cannot fix a fault quickly. Based on my experience last year (not with Plusnet), if BT Openreach miss their initial fast response target then you drop to the bottom of the queue as all their engineers are busy trying to fix other people's faults within a few days.
This is exactly why targets are sometimes bad. If you fault it a tricky one, the easy way to hit the 80% target is to concentrate on the 80% that are easy fixes....
10-07-2014 11:35 AM
80% of faults within 2 working days
100% of faults within 10 working days
£10 per day compensation for any days after 10 working days where a fault remains unfixed.
- Feedback
- Plusnet Feedback
