BT Wholesale upgrade
eddum
Re: BT Wholesale upgrade
connection seems more stable than before running through the fault checker, but has reconnected once or twice this evening.
speed from the my broadband speed test is better but still poor.
James
Can you show me some of the results that you have been getting from that site please?
eddum
errr.. what site ?  Huh
James
My broadband speed test is better but still poor.
I thought you were on about http://www.mybroadbandspeed.co.uk ?
eddum
ah yes... i was. .cant access them till i get back tonight.. i think we were approaching 200 kbps last night.
was a bit frustrated that the fault checker links you to a different speed test to the connection settings speed test page.... and then tells me i should have 3 test results before continuing !..... well i have several results from mybroadbandspeed.... but only one now from the BT tester and a 3hr gap required between tests !   anyway i guess the result of my one test was rubbish enough to bypass that as the fault checker moved on fairly sharpish after that.
more later...
jim:quote
eddum
Date  Download Speed  Upload Speed
Today 22:03  198 kbps (24.8kB/s)  380 kbps (47.5kB/s)  Share
Yesterday 21:51 239 kbps (29.9kB/s) 378 kbps (47.3kB/s) Share
Yesterday 21:22 168 kbps (21kB/s) 379 kbps (47.4kB/s) Share
Yesterday 20:26 215 kbps (26.9kB/s) 379 kbps (47.4kB/s) Share
Yesterday 19:09 199 kbps (24.9kB/s) 380 kbps (47.5kB/s) Share
Yesterday 18:55 170 kbps (21.3kB/s) 382 kbps (47.8kB/s) Share
Yesterday 18:48 215 kbps (26.9kB/s) 381 kbps (47.6kB/s) Share
Yesterday 17:48 223 kbps (27.9kB/s) 382 kbps (47.8kB/s) Share
Yesterday 17:36 245 kbps (30.6kB/s) 382 kbps (47.8kB/s) Share
Yesterday 06:58 34 kbps (4.25kB/s) 379 kbps (47.4kB/s) Share
Monday 22:14 55 kbps (6.88kB/s) 337 kbps (42.1kB/s) Share
Monday 21:57 53 kbps (6.63kB/s) 377 kbps (47.1kB/s) Share
Monday 21:44 67 kbps (8.38kB/s) 373 kbps (46.6kB/s) Share
Monday 21:12 98 kbps (12.3kB/s) 369 kbps (46.1kB/s) Share
Monday 21:10 105 kbps (13.1kB/s) 371 kbps (46.4kB/s) Share
Aug 11, 20:30 5785 kbps (723kB/s) 532 kbps (66.5kB/s) Share
Aug 11, 20:30 6059 kbps (757kB/s) 534 kbps (66.8kB/s) Share
James
Thanks Ed.
I've raised your fault to BT.
In the meantime could you please stay connected to your master socket.
eddum
thanks... and thanks for all your support here.. and there !
i did wonder if james here & james there correlated  Cool
although now i don't know where best to respond!
faceplate is currently on the master socket with a splitter.
modem has its own filter directly off the splitter, phone has it's own filter at the other end of an extension lead.
James
It's the same James Wink
Is the extension lead filtered?  It's very important that it is, or it may cause the interference that's affecting your speeds.
eddum
hmmm not currently but then i dont think it ever has been.
its been in a few different configurations over this last week so i'm a bit fuzzy on that.
James
Can you try filtering the extension for me please?
It might help.
eddum
hmmm.. just had dismal connection.. so rebooted router and speed test whizzes round nicely.
will keep an eye out for disconnections tonight/tomorrow & update ticket as appropriate.
eddum
James
..any chance of an translation of whats going on with BT at the moment ?
James
Right, the latest appears to be that BT have made a change to the noise profile on your line.
This happened at 11:15 - Any joy since this happened?
eddum
change yes... joy no.
i got home at just after one (intending to work from home for the afternoon) to find no connection at all..... gave up at just after two.
now in coffee shop !
