BT Speed Tester throws up ERROR/S
- Feedback
- Plusnet Feedback
- BT Speed Tester throws up ERROR/S
07-10-2011 4:53 PM
I have been trying to run a BT Speed Tester for last 3 days and every time it goes upto Checking User Details and then " Test Error - The performance tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists raise the issue with your service provider". When I try after an hour or so, I get exactly the same message after reaching checking user details. The Beta test is running fine, but it does not give me the profile.
Is there an issue with the BT speed tester? or Do I have a problem with my line?
I hope someone enlightens me on this issue.
Regards,
Chandu.
Re: BT Speed Tester throws up ERROR/S
07-10-2011 6:39 PM
07-10-2011 7:40 PM
Hopefully though, once the new profile system is fully rolled out, the BT Speedtester will not be so important.
07-10-2011 8:04 PM
07-10-2011 8:41 PM
07-10-2011 8:46 PM
07-10-2011 8:52 PM
08-10-2011 2:02 AM
(And the BT speedtester works for me.)
08-10-2011 8:15 PM
Quote from: Trevor Don't take it personally - it always comes as a surprise when the BT Speedtester works for me! I generally try to run it once a week and it will sometimes sulk for two or three weeks and then behave perfectly for a month. I have never yet found a cause for the unreliability.
I think Trevor seems to be right. I have just updated Java to Version 6 Update 27 and still the same error message.
By the way I use Firefox 3.6..23 as my default browser.
I will have to find a corner to go and sulk for a while .
Thanks for your help and updates, guys.
Regards,
Chandu.
08-10-2011 8:19 PM
Quote from: Oldjim Now that is interesting that link says I should update to Version 6 Update 27 but Firefox Plugin check says Version 6 Update 26 is up to date
Yes, Jim, I found exactly the same as you did. In any case I have now updated to Update 27.
Regards,
Chandu.
10-10-2011 4:46 PM
You might like to know that the BT speed tester has started to work again - no changes made.
Regards,
Chandu.
