At my wits end......
- Feedback
- Plusnet Feedback
- At my wits end......
01-04-2010 9:02 PM
In fact as I am typing this, cannot post, as noise margin dropped from 9dB, to -1.5dB. WTF
Re: At my wits end......
01-04-2010 9:39 PM
Sounds like a very frustrating experience you've had so far...
Not sure what staffing levels will be like over Easter though, so whilst you'll hopefully get a response from Plusnet soon, it could be Tues now before anything more can be booked with BT (with further delays due to them catching up from being off). I hope this isn't the case, but best to slightly lower expectations for a few days just in case.
I know Plusnet will be keen to get this resolved for you, but the BT system of sending different engineer after engineer to run the same checks for two hours as the last one did must surely be the problem with so many faults like your that drag on. It feels like they need a faster process to escalate all but the simplest problems to someone to manage from beginning to end. They stay until they crack it. If it needs further work, send out the same person to take it further. etc
I'm sure most people would prefer to be flexible about when a BT guy came if they would get the same one back, rather than watch as a new guy does the same old checks time after time!
Good luck with your fault, and I hope you get it resolved soon.
Mike
01-04-2010 9:49 PM
Thanks, yes its very frustrating, its also frustrating, that the faults team cannot be contacted directly, I called tonight, got a CSC rep, who unfortunately bore the brunt of my frustration, and if CS read this, I am sorry. Was told there is no way to talk to faults, but how can different CSC agents be expected to resolve ongoing issues. i feel some reorganisation needed.
I realise its not Plusnets fault, but BT. Why cant they see, it must cost more, to keep sending different engineers out, who have no idea whats gone on before etc etc, rather than just give a resonable time frame of 3-4hrs, for the engineer to do proper fault checks, and find the fault. BT want to escalate this to a level4 faults engineer, whatever that is, but they say there is nothing wrong with D or E side, but looking at my stats, there must be. Current stats below. Attenuation is usually 43-45dB, and I am on Daves DLM trial, with 9dB up and down. Obviously an issue I think. Usually sync at around 7000ish down, and 850ish up, when line OK, with an attn down of 45dB, and SNR of 9dB.
Rate: 4458 kbs 116 kbs
Max Rate: 6105 kbs 212 kbs
Noise Margin: 15.3 dB 8.9 dB
Attenuation: 47.0 dB 26.2 dB
Output Power: 19.8 dBm 11.8 dBm
06-04-2010 8:57 AM
I can see we've got an engineer visit booked for this morning, hopefully that should get things sorted for you - we'll be in touch this afternoon to see how it all went. If you could post back advising how things have gone that'd be great also.
06-04-2010 9:13 PM
Rate: 7184 kbs 875 kbs
Max Rate: 7184 kbs 875 kbs
Noise Margin: 5.7 dB 4.7 dB
Attenuation: 45.1 dB 24.5 dB
Output Power: 20.3 dBm 12.4 dBm
Collected for 2Days22:44:52
Since Current Current Time Since
Reset 24-hr int. 15-min int. Last Event
ATM
Last Event
Cell Header Errors 36910 1108 0 0:29:04
Loss of cell Delineation 35234 957 0 0:29:04
DSL
Link Retrains: 15 7 0 6:34:35
DSL Training Errors: 33 25 0 6:33:09
Training Timeouts: 4 4 0 8:54:59
Loss of Framing Failures: 27 15 0 6:34:35
Loss of Signal Failures: 27 15 0 6:34:35
Loss of Power Failures: 0 0 0 0:00:00
Loss of Margin Failures: 430 15 0 6:34:35
Cum. Seconds w/Errors: 1417 140 0 0:29:04
Cum. Sec. w/Severe Errors: 640 20 0 6:34:35
Corrected Blocks: 56455 6437 85 0:00:10
Uncorrectable Blocks: 36984 1135 0 0:29:04
DSL Unavailable Seconds: 4077 3705 0 6:32:50
07-04-2010 8:49 AM
I've noticed your update to the ticket regarding the buzzing noise, I'm happy to report this for you but it'll mean closing the broadband fault while the phone fault is investigated. On the bright side that'll certainly reduce the number of errors and if you're still getting disconnections it should stop those as well.
I'm posting this rather than raising the fault straight away as I need to make sure you're happy that the broadband fault will be closed when we report the fault on the phone line. If so post back and I'll get the phone fault raised.
07-04-2010 10:57 AM
07-04-2010 11:38 AM
To pre-empt your next question - yes, we will be looking at updating the faults wizard, but we don't have any set dates at present.
EDIT to add: It does, in the event of an intermittent connection, ask if the call drops at certain times i.e. when a phone call is made or received however.
07-04-2010 11:50 AM
It is obvious that it should be there as a question in the fault checker. It could save lots of time and faffing in the process if voice faults got weeded out of the mix right at the start, and tackled as such from day one.
I look forward to hopefully seeing this get implemented in the future....
Mike
07-04-2010 1:06 PM
07-04-2010 1:40 PM
11-04-2010 8:30 PM
Well I did have my fingers crossed, but it wasnt to be...... After 4 days of a consistent sync all hell broke lose this afternoon....... The connection has finally settled down, but have phoned the CSC, to bounce this back. The agent also mentioned that no engineer notes were to hand, I would be interested to note his findings.... Anyhow, just what can be wrong with this line??? The engineer admitted, that they were running out of ideas. Has anyone ever had a complete new line run at all?? I am now stumped, and at a loss, as to what to do next. I even went out to buy another router, just in case, but no luck, and I also left the phone disconnected for 2 hrs, again just in case....... Nothing helped. I have again removed the XTE-5 faceplate, and am now connected via the test socket, with a filter, but surprisingly, everything since this appears stable, this has never happened before
EDIT. Lost sync 5 times over the past few mins
11-04-2010 10:47 PM
The changed faceplate claiming capacitance was out. The engineer had wird idea about how routers work as well.
could it be possible if no faults are found on your line that not all PN or Bt systems have caught up with your change in connection type eg radius etc.
12-04-2010 10:17 AM
Yep, I can see the dropping connections have returned. We're looking into it for you now, there'll be an update shortly.
13-04-2010 3:47 PM
In the house the line comes in throught the front window, to a little box (Its not an RF filter), past a couple of leccie sockets, to the Master. The drops seem completely random though. Interestingly, every time BT come and fiddle, its OK for a couple of days, and then starts again. I would LOVE to know what BT do. I wonder if its worth asking for a lift and shift?
I have a 2wire HGV2700. How do I go about using routerstats. If they wont run on this, I do have a Speedtouch 585V6. If I use routerstats, does the PC have to stay on. SOrry for my ignorance, never used this app before.
