Appalling service over 10 years with PN but what to do
- Feedback
- Plusnet Feedback
- Re: Appalling service over 10 years with PN but wh...
27-12-2013 7:27 PM
I have been with plus net for as long as I can remember, maybe 10 years. I was 5 km from the exchange and over the years my connection speed has gone from 512kbps to currently 12mbps so you would say I am a happy customer.
The problem is this, although my download speeds have been going up (especial with FTTC) the errors on my line are huge and I have to reboot the router every hour to reset its self and give me connection.
This is caused as I am on the end of a very old line which has multiple terminations over the years and repairs and also included a section of aluminium.
I have over the last 3 years complained bitterly to plus net and BT have in turn sent out and engineer, but they have said there is nothing to do and lump it unless I want to go down in speed which actually won't improve the error problem.
I can't believe that either company and remember my contract is with PN can just turn their back when they know full well what the problem is but won't do anything due to cost.
There are at least 3 other houses on the same line and they have the same problem but with different service providers
How do I put pressure on PN and how do we as a community put pressure on BT wholesale.
I have a background in communications so fully understand the issues and also the bullshit give to me as excuses.
J
dick:red Offensive word removed as per forum rule.
Re: Appalling service over 10 years with PN but what to do
27-12-2013 7:38 PM
27-12-2013 8:13 PM
You can see how big the forward error corrections is just after a few mins
VDSL
Link Status Showtime
Firmware Version 1414c3
Basic Status Upstream Downstream Unit
VDSL Profile 17a
Actual Data Rate 650 18607 Kb/s
SNR 62 65 0.1dB
Advance Status Upstream Downstream Unit
Actual delay 0 0 ms
Actual INP 0 0 0.1 symbols
15M CV 820 1 counter
1Day CV 820 1 counter
15M FEC 0 74088 counter
1Day FEC 0 74088 counter
Total FEC 0 74088 counter
Previous Data Rate 0 0 Kbps
Attainable Rate 659 18607 Kbps
Electrical Length 321 321 0.1 dB
SNR Margin 62 62 (US0,--) 0.1 dB
SNR Margin 0 65 (US1,DS1) 0.1 dB
SNR Margin 0 N/A (US2,DS2) 0.1 dB
SNR Margin 0 N/A (US3,DS3) 0.1 dB
SNR Margin 0 N/A (US4,DS4) 0.1 dB
15M Elapsed time 128 128 secs
15M FECS 0 43 counter
15M ES 824 1 counter
15M SES 18 0 counter
15M LOSS 55 0 counter
15M UAS 39527 27 counter
1Day Elapsed time 128 128 secs
1Day FECS 0 43 counter
1Day ES 824 1 counter
1Day SES 18 0 counter
1Day LOSS 55 0 counter
1Day UAS 39527 27 counter
Total FECS 0 43 counter
Total ES 824 1 counter
Total SES 18 0 counter
Total LOSS 55 0 counter
Total UAS 39527 27 counter
27-12-2013 8:51 PM
Have you a different router to try
Also have you tried the quiet line test - dial 17070 option 2 and is the line quiet
Also can you describe the connection between the telephone point and the router - type of wire, length and is is coiled up or laid straight
EDIT - Electrical length isn't directly comparable to attenuation as it doesn't appear to take account of the frequencies used and is a Draytech peculiarity so upstream and downstream are the same and don't actually tell us very much
27-12-2013 10:53 PM
Quote from: jonnyhottub unless I want to go down in speed which actually won't improve the error problem.
I don't understand that comment. A higher target noise margin will reduce the sync speed, but should also reduce the error rate.
27-12-2013 11:48 PM
28-12-2013 10:30 AM
While awaiting the information requested one solution would be to push up the default noise margin which, despite what you have been told may well ameliorate the problem at the expense of speed. However since the problem appears to, at least partly, affect the upstream connection this may not be entirely practical or effective as the highest available default upstream noise margin is 9dB interleaved as explained here (last link in the first post) http://community.plus.net/forum/index.php/topic,119921.0.html
28-12-2013 12:15 PM
There was minimal noise on the line during the quiet line test.
Some more back ground
There is only a 200 meter section of aluminium cable rest is copper. total distance is about 1km from box. I don't understand why router reports only 323?
There have been many joints over the years on the line as the farmer has dug up the cable and broken it.
One major junction box sits in water! and although I have seen this with my own eyes with BT engineer they say it doesn't matter as their boxes are water proof! which I accept but what happens when the water freezes etc
I use a Draytek 2850
I have same result with standard BT open reach modem
When i was adsl my upload speed was slightly higher.
One of my questions apart from trying to find the fault is how Plusnet ( for who my contract is with) can just turn a blind eye as BT are not willing to short the problem out.
Where are Plusnet Terms and conditions which state what they should provide as a level of service?
I have been moved to a different pair on the line many times which has improved speed but FEC and therefore reliability increases.
I am not really bothered about download speed as long as its over 8mb its the upload and constant drop outs that cause the issue.
Current modem data
VDSL
VDSL Profile 17a
Actual Data Rate 642 18637 Kb/s
SNR 60 43 0.1dB
Actual delay 0 0 ms
15M CV 0 3 counter
1Day CV 820 4294 counter
15M FEC 0 60 counter
1Day FEC 0 6323528 counter
Total FEC 0 6323528 counter
Attainable Rate 636 18637 Kbps
Electrical Length 323 323 0.1 dB
SNR Margin 60 60 (US0,--) 0.1 dB
SNR Margin 0 43 (US1,DS1) 0.1 dB
15M Elapsed time 602 602 secs
15M FECS 0 32 counter
15M ES 0 3 counter
15M SES 0 0 counter
15M LOSS 0 0 counter
15M UAS 0 0 counter
1Day Elapsed time 55502 55502 secs
1Day FECS 0 27470 counter
1Day ES 824 1262 counter
1Day SES 18 40 counter
1Day LOSS 60 0 counter
1Day UAS 39624 3917 counter
Total FECS 0 27470 counter
Total ES 824 1262 counter
Total SES 18 40 counter
Total LOSS 60 0 counter
Total UAS 39624 3917 counter
28-12-2013 12:19 PM
There is occasional noise on the line and this is very intermittent and only once has the actual BT engineer seen this noise other times when they arrive its clear and the only thing to go with is when Plus net log the drop outs which can happen unto 6 times a day
29-12-2013 9:17 AM
There are still quite a large number of premises in the UK that cannot get any significant broadband service, and there will still be, even after the megabuck spends due over the next 2-3 years. Very unfortunate but I don't think that anyone can force BT to spend excessive amounts for these marginal lines.
29-12-2013 11:04 AM
As previously requested can you describe the connection between the telephone point and the router - type of wire, length and is is coiled up or laid straight
You misunderstand the terminology in your stats and my comments on it.
Quote There is only a 200 meter section of aluminium cable rest is copper. total distance is about 1km from box. I don't understand why router reports only 323?
The Electrical Length 323 323 0.1 dB refers to the effective signal reduction over the whole connection from the exchange to your router and is in units of 0.1dB so the figures are 32.3dB. This is apparently a peculiarity of the Draytech system in that it reports the upstream and downstream as the same so God knows how it calculates it.
We need the figures from the BT modem to get some idea of the actual attenuation
29-12-2013 11:15 AM
@johnnyhottub, I'm surprised that the Draytek is reporting both Actual Delay and Actual INP with zero values, these are both related to error correction and for an error-prone line I'd expect non-zero values.
29-12-2013 2:03 PM
30-12-2013 12:19 AM
30-12-2013 12:26 AM
- Feedback
- Plusnet Feedback
