Apathetic responses to loss of speed issues!!!!
- Feedback
- Plusnet Feedback
- Apathetic responses to loss of speed issues!!!!
24-08-2015 1:36 AM
Quote Dear Mr Mcgough,
Thank you for your patience.
I have tested your line and can see that your connection is performing within the acceptable limits for the line.
The minimum throughput speed acceptable for the line is 47.76mbps, so unless the speed drops below this level we are unable to treat the matter as a fault with our suppliers.
This basically infers that they can't be bothered to do their job, the issue itself was simple, I was connected/synced at the max rate and ip profile from BT, for some reason Plusnet decided to push down the speed from their end. Again I had no problems with this it was something easily rectified over Live Chat I might.
Anyone that has raised these tickets will be aware it comes with a boat load of bumph attached in the intervening replies to the ticket.
What I am so annoyed at is this absolute apathy for raisin a minor issue, I appreciate Openreach get involved unless my levels fall below those stated in the quote. However for the avoidance of doubt I have had my line tested several times in the past and it is capable of max speed and profile (taking account of overheads naturally). That was direct from an Openreach engineer.
The point I'm making if I contact you again, the so called 57.4Mb capability will be stated and that my line is within range.....this is not helpful!!!!! NOT AT ALL!!!
Why can't it be simple, I come to you with a problem you look at it and offer something constructive?? You have access to a panel of information which will likely tell you the sync rates and likely download speeds, I came to suffering some speed loss and that is what I get when I raise a ticket.
This website and maybe company is becoming more hostile to the client, raise something in Forum it gets overlooked, raise a ticket you have to jump through a set of hoops, speak on the phone and you are waiting 15 mins on average, live chat and there are 5 people in front of you......need I go on?
I am happy with the broadband itself generally speaking, its the service side which is clumsy and feckless, why can't anyone think outside the box and just look at the bigger picture rather than picking something a part and then saying you can't help?
The other thing I should add, in the months from when I first joined in February up until June I was suffering with those capacity or speed complaints, I have emailed the person handling this apparently and no reply. The point is I want a refund or partial for those months, or is that another email to the MD?
Re: Apathetic responses to loss of speed issues!!!!
24-08-2015 2:29 AM
24-08-2015 7:16 AM
24-08-2015 2:10 PM
24-08-2015 2:22 PM
Quote from: Anotherone Your BQM is symptomatic of the congestion issues reported in this Capacity thread. A Gateway hop may help.
Quite the opposite. That BQM is unlike any other on that thread.
@ jmcgough - Are you using your connection at all for anything else when running the speed tests? Are you upload/downloading large amounts of data?
24-08-2015 2:41 PM
Perhaps you should have asked how I concluded that before contradicting me
And I still say with respect to that issue, a gateway hop may help.
With regard to the current activity, if jmcgough is using the 2704n router and uploading a lot, the problem of download throughput being affected seems more prevalent going by other reports on this forum.
24-08-2015 2:47 PM
The graph is indicative of either a fault or heavy usage - it is not consistent with what anyone else has posted on the capacity thread. The timing of the packet loss/latency increase outside of peak times is further evidence of this.
24-08-2015 3:01 PM
Quote from: Anotherone When I initially reviewed it, it was showing the typical hump in the minimum latency and average latency consistent with congestion. The current display clearly shows different activity.
I suggest you see this graph and this rather exaggerated graph as some examples of capacity type issues.
24-08-2015 3:15 PM
The OP needs to elaborate on his usage firstly.
24-08-2015 3:25 PM
Quote from: Anotherone The current display clearly shows different activity.
It shows some heavy usage and it will be interesting to know what performance was like during that period.
24-08-2015 3:34 PM
Quote from: AndyH I have no idea what you were reviewing, but it looks clear to me.
If you are unable to read and understand what people post I suggest you butt out!
Quote from: Anotherone AndyH, IF you had looked at the BQM more closely, you would see that it is a live BQM. When I initially reviewed it, it was showing the typical hump in the minimum latency and average latency consistent with congestion. The current display clearly shows different activity.
If you see a graph with the dotted white line and the date stamp half way along that tells you it is a live graph or a snapshot of today's. In both cases the earliest information that was present at the time the post was made will have since disappeared.
24-08-2015 4:14 PM
24-08-2015 4:20 PM
24-08-2015 4:27 PM
Could you post yesterdays graph please
24-08-2015 5:11 PM
Day before
Again as I say I wasn't intending to mislead, I really do apologise if it appears that way.
I was downloading several large files yesterday, thats why my BQM looks busy.
My complaint is more round the customer service side, not the actual connected per se, once again I really am sorry.
- Feedback
- Plusnet Feedback
