Am I destined to be stuck on 1Mb Slowband forever?
- Feedback
- Plusnet Feedback
- Am I destined to be stuck on 1Mb Slowband forever?
21-09-2011 3:40 PM
Re: Am I destined to be stuck on 1Mb Slowband forever?
21-09-2011 3:42 PM
21-09-2011 3:53 PM
http://community.plus.net/forum/index.php/topic,97499.msg823411.html#msg823411
It may be something to do with "grandmothers eggs and sucking" but I had a similar experience experience. 4/5 years on about 800Kbps and then I joined PN. The problem was my internal wiring but the previous ISP didn't advise me.
Just a thought
To be is to do - Kant
do be do be do - Sinatra
21-09-2011 8:05 PM
These are my linestats:
--- System Information ---
Vendor: Linksys
ModelName: WAG320N
Firmware Version: 1.00.12 , 2010-03-22T10:51:43
Boot Version: 1.06
Hardware Version: 0.01
--- DSL Information ---
DSL Driver Version: AnnexA version - A2pB023k.d21d
DSL VPI/VCI: 0/38
DSL Status: Showtime
DSL Mode: G.DMT
DSL Channel:
DSL Upstream Rate: 448 Kbps
DSL Downstream Rate: 2208 Kbps
Down up
DSL Noise Margin: 4.9 dB 9.0 dB
DSL Attenuation: 63.5 dB 31.5 dB
DSL Transmit Power: 17.5 dBm 11.9 dBm
21-09-2011 8:09 PM
Out of interest what does the BT speedtest give
21-09-2011 8:57 PM
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
1520 Kbps
21-09-2011 9:02 PM
21-09-2011 9:24 PM
I suspect fibre is the only way you will get faster speeds, as happened to me.
21-09-2011 9:43 PM
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :2208 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1750 Kbps
21-09-2011 9:46 PM
21-09-2011 9:55 PM
21-09-2011 10:25 PM
21-09-2011 10:40 PM
http://www.btplc.com/News/Articles/Showarticle.cfm?ArticleID=6B440E94-F7D0-4317-BAD8-7391B44783A7
21-09-2011 11:47 PM
Sam knows results show how dire it is round here!!
http://www.samknows.com/broadband/exchange/EMTWCRO
24-09-2011 1:14 AM
Quote from: samskellern So will I ever get fibre? Whatever happened to the government promise of 2mb for all?!!
Ah that was a whole government ago!
I was actually at a rural broadband conference in Suffolk earlier this year which had a keynote speech given by Ed Vaizey, the minister in charge or Broadband. In a nutshell, he said that they had dropped plans for 2mbs broadband to become part of the universal service commitment because they had decided that it was not sufficient and there had been a general refocus on providing super fast (40mbs+) broadband.
I can see the reasoning behind this, why continue to push a technology that's already out of date however it doesn't help people that genuinely can't get broadband.
There is a glimmer of hope in that mobile operators can now use the 2G spectrum for 3G services which should help them to rollout mobile broadband to rural areas however on an exchange with less then 1000 users it's pretty unlikely you'll see FTTC any time soon.
I share you're pain!
- Feedback
- Plusnet Feedback
