A sign of things to come ?
- Feedback
- Plusnet Feedback
- A sign of things to come ?
Re: A sign of things to come ?
19-05-2013 8:12 PM
And no you haven't made a mistake. If you want Fibre you would have this problem whoever the ISP in the case of a fault like this. But you get better support here.
19-05-2013 8:52 PM
The fact that he said he'd close the job with relevant notes should give hope of further action to resolve the problem.
20-05-2013 9:55 AM
I can see we have got notes, basically detailing what was tested and how (including the mention of the JDSU) however they state that testing showed no faults and that the engineer was able to demonstrate line tests that showed no problems?
Please let us know if that's the case and also if the issue is still ongoing (I'm assuming so given your update yesterday) and and we'll pass the fault back for further investigation.
20-05-2013 10:05 AM
20-05-2013 11:04 AM
20-05-2013 12:02 PM
20-05-2013 12:18 PM
Edit:
I do have to appologise for my communication rant yesterday as I have just noticed this added to my ticket:
Script User - Automated Script Pool
6:05pm, Friday 17 May 2013
We would like to inform you that your Help Assistant Question [ 69458217 ] has now been returned to the BOT - FTTC Logged Faults - Post SFI pool. A member of our Support Team will investigate your issue as soon as possible.
But to be fair my Main Help Assistant page states:
11 May 2013 69458217 Awaiting support team answer ViewClose
So without clicking on view I assumed It had not been modified since 11th May hence i didn't press "View", It would be handy if there was some sort of notification (txt,email) when a ticket is amended.
20-05-2013 12:47 PM
20-05-2013 4:02 PM
I'm starting to agree with Anotherone here in that it may well be a hardware issue, as your downstream line rate is solid at 72Mb/s. Please could you run two BT speed tests (http://speedtest.btwholesale.com) - one when connected directly to the modem, and one with a wired connection to the router - and we'll take things from there? Most likely is that we'll get you another router out.
20-05-2013 4:31 PM
20-05-2013 5:58 PM
Quote from: Matt Hi simonb1,
It nothing like solid at 72mb ?
Quote from: simonb1 PPPoE is erratic, as previously stated it can be anything from 40mb to 73mb never constant, 1 test varies from the next in a short space of time.
Test 1: Directly to the Plusnet Router (using a different port)
Download speedachieved during the test was - 44.34 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-77.44 Mbps .
Additional Information:
IP Profile for your line is - 77.44 Mbps
Upload speed achieved during the test was - 14.83Mbps
Test 2: Directly to Openreach Modem using PPPoE
Download speedachieved during the test was - 45.79 Mbps
Upload speed achieved during the test was - 14.43Mbps
Test 2 again: 10 minutes later
Download speedachieved during the test was - 63.82 Mbps
Upload speed achieved during the test was - 15.36Mbps
20-05-2013 6:31 PM
Quote from: simonb1 It nothing like solid at 72mb ?
Matt is talking about your sync speed to the Cab. And the fact that it is solid is something to be very thankful for. Line issues can be a far worse problem to deal with in some circumstances.
From your last tests, (and taking note of your more recent comments) this tends to suggest that the Router is not OK.
What I find more interesting, is the fact that you will have had several drops in PPP sessions as a result of the testing, yet the BTw speedtest is still showing a Profile of 77.44 (and has done throughout) which equates to a sync speed of 80Mbps whereas Matt is seeing 72Mbps.
So something in BTw's systems is somewhat screwed up which takes us back to the comments made by the Engineer on Friday. Whether this is the DSLAM in the Cab or something further upstream at the exchange causing this I wouldn't know, more likely the DSLAM.
Edit: Correct typo giving wrong comment about Router.
21-05-2013 12:47 AM
And I am starting to believe its the plusnet router as Matt suggests, as whilst hard connected to that
Im willing to try a replacement router
21-05-2013 5:20 AM
To go back to last Friday, reply #24 - was that first test via the Router? And was the 2nd test exactly the same connection?
The fact that Matt says he sees 72Mbps, and the fact that the Speedtester continues to show a profile of 77.44Mbps, along with the engineer comments clearly suggests that there is a problem on BT's systems, taking note of the engineers comment probably at the Cab DSLAM.
Whether this accounts for the variability in uncertain, but possible. A fault on the DSLAM could cause it, but to me the timing of the slower results throws a suggestion of congestion into the mix. It won't be congestion at the Cab if you are the only (or possibly one of few) users now on the Cab, but it could be Exchange or BT backhaul.
Before you post the next BTw speedtest result, can you make sure you have logged into the Router and clicked Disconnect to drop the PPP session, waited 30 seconds and clicked Connect.
A look at the Radius log by Plusnet would be a good idea to see if BT and Plusnet systems are seeing PPP session stops and starts.
Can you also confirm whether you have recently heard any crackling or other noises on the line when using the phone? Have you had any problems with incoming or outgoing calls? You were asked earlier by someone if you suffered any drops on your previous BE ADSL connection?
21-05-2013 9:42 AM
Ps Matt
Ticket still hasn't been responded to.
Edit:
Sorry didnt answer your question about #24, Both those tests were done via the Openreach modem using PPPoE (same session)
