A bit of faith
- Feedback
- Plusnet Feedback
- A bit of faith
A bit of faith
09-02-2014 7:01 PM
However my old Thompson 585v8 finally bit the dust so called up to get a replacement, and had to sign up for a 12 month contract to get it. Come on, you have that little faith in your long term customers that your that scared they will run off with a £36 piece of hardware? (http://www.amazon.co.uk/Technicolour-TG582n-Port-Wireless-Router/dp/B005ELFTH4). Keep your service as good as it is and you wont need to lock us in over £36, we'll be staying put regardless!
Re: A bit of faith
09-02-2014 10:09 PM
Re: A bit of faith
09-02-2014 10:31 PM
Re: A bit of faith
09-02-2014 10:59 PM
In addition to the above, 'Sprats to catch mackerel' also springs to mind.
If you have no intention of leaving within the next 12 months then you have 'nothing to loose', alternatively there are cheap routers available with adequate spec. which will avoid the 'tie-in'.
You're the customer, it's your choice.
My own preference is to use a much better router that, hopefully, will work with any ISP I might use now or in the future (though I have no reason or wish to leave Plusnet at present).
Re: A bit of faith
09-02-2014 11:06 PM
Re: A bit of faith
09-02-2014 11:08 PM
Still reasonable value for existing customers though.
Re: A bit of faith
09-02-2014 11:22 PM
I doubt they make much profit from the average customer, not enough to pay for a router, but presumably there's a trade-off in (hopefully) reduced support calls from those supplied with a standard preconfigured router.
Re: A bit of faith
10-02-2014 8:05 AM
Quote from: 77 Still reasonable value for existing customers though.
I'd say it is still good value for existing customers. I can't find anywhere else which would offer me the same service/features for less money than I'm paying.
Re: A bit of faith
10-02-2014 9:07 AM
I'll ensure this is passed on to the relevant team.
Re: A bit of faith
10-02-2014 3:17 PM
A not too small part was knowing from experience of the great help that is available from PN Staff monitoring these forums, fortunately I haven't had to make use of it all that often.
Re: A bit of faith
13-02-2014 2:47 PM
Compared to my last provider (TalkTalk), PN are so much better, both in broadband performance and customer service.
Nothing is perfect, but compared to some of the other providers out there, I think PN is a good choice.
Re: A bit of faith
13-02-2014 4:03 PM
