2 weeks with Plusnet, great broadband, poor hardware!
- Feedback
- Plusnet Feedback
- 2 weeks with Plusnet, great broadband, poor hardw...
31-10-2012 8:10 PM
However the supplied router is poor quality, i've had 2 so far and both have been faulty.
The first makes a really irritating high-pitch squeeling noise which means i cannot be in the same room without having the tv or radio on to drown it out!
Also the wireless is next to useless, worse than the very first 802.11b router I had 10+ years ago, can barely reach the next room and the bedroom directly above!
Was sent a replacement, which was faulty straight out the box, no wireless at all! The ssid shows up and I can connect ok (yes password is correct
The modem side seems ok however, I briefly considered using it as a modem together with an old cable router i have laying around. Unfortunately there is no official setup option for this but it's possible with telnet commands. There's some brief instructions around the forum and it does work but i think really it's better to just get a half decent all-in-one solution.
I'm hoping Plusnet will accept both faulty routers back and refund my fiver postage to put towards some better hardware!
Re: 2 weeks with Plusnet, great broadband, poor hardware!
01-11-2012 9:23 AM
Really sorry to hear you've had issues with 2 routers from us. We certainly will refund your postage and packing for you and we'd be interested to receive those routers.
We'd usually handle router returns or replacements via our warehouse but I'm wondering if you'd mind returning those back here as In total and complete honesty you've been very unlucky to have issues with 2 routers in a row and we're especially interested in looking at the one that's producing the high pitch noise.
With regards to the wireless issue with the first router I'm wondering was the adapter on the device you were connecting to it with N capable or configured to connect as N?
Could I ask that you return those routers back to the following address, with a receipt for the postage costs and I'll also make sure that is refunded in full too:
FAO Adam Walker
The Balance
2 Pinfold St
Sheffield
S1 2GU
01-11-2012 11:06 AM
01-11-2012 11:23 AM
I have a white PN ROUTER and its outstanding ,,
my computer/router is upstairs and tellie down stairs....
the wi-fi (N ) signal is amazing,,, all over the house,,,
may be your walls are thicker type.. emmm...
01-11-2012 2:48 PM
01-11-2012 10:23 PM
Ok, will do - thanks.
The various devices tried were:
my oldish laptop - G - same room
desktop - N - room directly above
android tablet - N - all over
housemate's newish laptop - N - same room
housemate's iphone 4s - N(?) - all over
it's generally just overall poor performance everywhere, it's ok in the same room, poor in the next room, poor in the bedroom above and unusable in the back bedroom/conservatory/outside. But when i say ok, i mean usable but not good, eg. sitting about 3 meters away from it and my android tab is showing 50% signal !
Quote from: _Adam_Walker_ ... In total and complete honesty you've been very unlucky...
@kdoug007
Quote from: kdoug007 may be your walls are thicker type.. emmm...
Unfortunately not, just an average new build 2 bed semi, new build meaning the walls are about twice as thick as a rizla
01-11-2012 11:36 PM
04-11-2012 10:20 PM
12-11-2012 5:51 PM
21-11-2012 5:52 PM
I have been having a similar noise issue with my new router. I have been in touch with Adam via PM and he is looking into it for me.
Great service from the team, thanks again
22-11-2012 3:53 PM
13-03-2013 12:50 PM
13-03-2013 2:20 PM
There was another poster recently with the same problem. My 582n and it's PSU are silent.
It would be interesting to know the outcome of those investigations
16-03-2013 6:12 PM
16-03-2013 6:16 PM
- Feedback
- Plusnet Feedback
