16 days wait for ticket being reolved
rongtw
Fixes: 12
am totally annoyed wit PN,s ticket system and customer care, what a load of pooh  Crazy
16 days ago i raised a ticket #39762056, regarding bad connection problems playing online games, streaming videos, ie BBC i player,sometimes impossible to play online or watch a peogram on i player.
originally was asked to do 3 speedtest at BT, which was done , then was asked to do some tracerts to check line , then was told  9 days later it was escalated to the correct pool.
then was told to run PN fault checker , which told me they had all information required ?
then have waited another day to be asked if my pc was connected corectly !
then 4 days later i got this morning "Cannot raise fault via BBFC as fault already processing, EPP issue, please progress."
?? what does it  mean ?
sorry but am getting realy pee off now 16 days and still no sign of any attention to my fault and no help from PN  Sad
all i want is a stable line connection is this too much to ask !
36 REPLIES 36
adamwalker
Fixes: 223
Re: 16 days wait for ticket being reolved
That's actually good news, it means that the fault has been reported to our suppliers. EPP, meaning end user poor performance is the 'BT speak' for the type of fault you are experiencing. Following on from here I'll make sure we give this some more attention today and I must apologise for this issue having progresses so slowly so far, I'll do all I can to get things moving.
Also I will be giving feedback to the agents that have responded to your query so far as better use of plain English would not have gone a miss here!
Adam.
 Adam Walker
rongtw
Fixes: 12
cheers Adam for the translation  Cool i hope its sorted soon
adamwalker
Fixes: 223
No probs,
I'll make sure someone has a look at it for you.
Adam
 Adam Walker
rongtw
Fixes: 12
update  Wink well i actually had a phone call from PN staff this evening , helpfull and polite .
outcome is it looks like a problem with my line so he said he will get in touch with BT to check maybe connection fault.
wait and see how long it takes to resolve  Roll_eyes
cheers
rongtw
Fixes: 12
well i got a email this morning but once again its not in plain english  Sad
"SS provided by EU suggest an issue locally, 50ms + in getting a response from router.
Likely a wireless/driver issue. Speeds are fine, PTTR:" ?Huh
if its a wireless/driver issue it wierd as i connect thro a lan cable ,  then i got this
"For us to be able to progress the fault, please run a speed test illustrating the slow speeds. This will allow us to determine if the fault is still persisting. If the speed test shows normal speeds, it is possible that the issues lays locally with your computer or network. Ensure you are connected using an Ethernet cable, and that you have run a virus scan. Disable background software where possible, as some can download applications automatically. "
if they had read the posts on the ticket it points out the items the ask for have already been carried out , also i have stated i have done a HD format and total reinstall and nothing is set to auto start except ones needed by windows !
adamwalker
Fixes: 223
To be fair they are marked as internal comments. Just stick with the second response by the same person which is addressed to yourself.
I will of course give some feedback that the rest of the response could have been slightly better worded and that the agent could have taken more care to read the rest of the ticket. Could you run some further speed tests for us please? (using the BT speedtester). As this is our way of accountably proving the slow speeds to BT.
 Adam Walker
rongtw
Fixes: 12
well another few days have passed  Sad  and have had no change in my connection, have had no feedback from PN to say what is happening,
have done more speedtest on bt speedtester done several tracerts .
and still yesterday i get a error from bbc iplayer insuficcient bandwith to stream  >:(.
would be nice to find out what is being done by PN to find the problem .
adamwalker
Fixes: 223
I've replied to the ticket, just a few more bits of info needed from you for diagnostics. I can't see any issues with your speed in general though so it may be specific to streaming.
Adam
 Adam Walker
rongtw
Fixes: 12
cheers Adam have done test as asked ,  but cannot upload wireshark save file .
thanks
Ron
adamwalker
Fixes: 223
OK, I'll take a look again shortly what's happening when you try to upload the pcap files from Wireshark?
 Adam Walker
rongtw
Fixes: 12
nowt happens it just , stands still  Undecided , its not on list of alowed attachments here either  Sad
rongtw
Fixes: 12
aparantly they cant find a fault  Sad so they have turned interleaving on, reading about this i dont know if its a good thing for gaming, but will keep you informed .
cheers
Ron
adamwalker
Fixes: 223
Hi Ron,
How are things with the connection today? PS do let me know if this seems to fix the report issues but cause you problems with gaming and I'll see what I can do.
Adam
 Adam Walker
rongtw
Fixes: 12
Embarrassed well its ,,,,,,,,,,,,,,,,  same still get kicked for high ping occasionally, but servers are same as friends playing on and they dont have same prob ? some in uk some in sweden and holland its only me who has prob ,
have done wireshark captures and get loads of reds ?? so how do i upload for you to check
cheers
Ron
