14 day cancellation period is a total scam
bobbarian
Re: 14 day cancellation period is a total scam
i'm not on fibre.......the BT booster will not pair with the plusnet hub?
Fixes: 307
If you are not on Fibre, I am very surprised you have a Hub2. What product does it say you are on, in your Member Centre?
bobbarian
it says unlimited fibre but its actually not.well so ive been told by a BT engineer?....i've factory reset the booster and still nothing but when the booster is first installed it has to be conected to the router by ethernet so im wondering if i need to do the same with the hub 2?
Fixes: 307
If your product is shown as 'Unlimited Fibre' then the BT engineer is (as some of them tend to) talking rubbish. As regards the booster - if it had to be connected by ethernet for installation on the BT Hub, then yes, it will need the same procedure to connect to the Hub2.
bobbarian
ok thank you
Fixes: 444
@bobbarian
By way of explanation there are two versions of fibre. These are Fibre to the Cabinet, which is the service that you have and Fibre to the Home, which is not yet available to most premises or Plusnet.
As I suggested earlier, if you tell us the make and model of your booster we can possibly advise you how to configure it.
Fixes: 202
@bobbarian wrote:
i know its not a try it for free but you should be able to see the service, if you buy goods online the return policy doesnt start when you order it...
Completely different considerations.
The 14 day "cooling off" period is a remote selling protection which allows the purchaser to change their mind - it is intended to address high pressure sales tactics.
Buying goods and buying services are two entirely different matters - any "return if you do not like" policy is not a grant of law, but a grant of extended grace or guarantee.
As for the WiFi not covering your whole home, indeed, it might not cover everyone's mansion, as individual's castles can be very different.  The right approach here is to understand the characteristics of your home and then to modify YOUR home network accordingly - that might mean YOU acquiring additional WiFi equipment.
You have previously (in effect) already addressed such considerations - a BT router PLUS A BOOSTER (BT product?) against just a router are not going to give you the same coverage.  Was the booster a BT disc - a service / product which I believe has an additional price tag?
greygit
"Plusnet's (or any ISP's responsibility is to provide the service as far as your Master Socket - anything beyond that is out of their control"
Some stuff beyond the master socket is within their control. Example. The modem sits on the customer side of the master socket. PN provide the firmware on the modem. They provide further firmware updates. The firmware is configured to use CWMP with no control options for the customer to disable, therefore it could be argued that Plusnet have at (the very least) partial control of the modem and thus their control extends past the master socket. The modem gets autoconfig (with zero customer intervention or, it could be argued, control).
Just little observations. Perhaps the demark (abbreviation for demarcation) line isn't always at the master socket.
Similar observations may also be applicable to other ISP's modems.
lee74
not when the reresentative on the phone when you ordered specifically sais " your 14 day cooling of period does not start untill your service goes live"  as did the one i spoke to. i specificaly asked this same question when he gave me a insalation date of 3 weeks after i ordered .
Tina11192
Fixes: 15
Hi @lee74  thank you for taking the time to contact us on our Community Forum, I hope you are well.
The issue raised is concerning and I would like to look into this further, at your earliest convenience, please can you DM me your account username so that we can investigate this further, I have also private messaged you to trigger the response.
For completeness, the 14 days coll off period starts from the day after the account is created and not from the day the services go active.
I look forward to hearing from you soon
Cri Ignatti
