136185240 - no response after 3+ days
chenks76
All Star
Fixes: 12
136185240 raised on Monday 17th Oct.
not even looked at yet by the "support" team... certainly doing us all proud!
I'm sure the usual PN stooges will pop their head and and offer the same luke warm apologies that they always offer.
30 REPLIES 30
HarryB
Fixes: 256
Re: 136185240 - no response after 3+ days
At the moment responses to fault tickets are unfortunately still up to 5 working days.
Are you still experiencing packet loss now?
 Harry Beesley
chenks76
All Star
Fixes: 12
every time it goes to that specific gateway, yes.
a rock solid PPP connection that was previously having 60+days connection time has turned into PPP connections that drop every 3/4 days.
playing the gateway lottery is not something i want to do.
HarryB
Fixes: 256
Has it happened at all today? Could you post your live BQM if it has.
Thanks.
 Harry Beesley
chenks76
All Star
Fixes: 12
it's not happened today, but it was at the time of raising the ticket.
PPP dropped yesterday (i think) and the minimum latency jumped from 20 to 40).
66fa051c10acdbc9137d22dbaa6e5ddb-20-10-2016
chenks76
All Star
Fixes: 12
graph from the 18th showing packet loss then PPP drop to 40mb minimum latency
HarryB
Fixes: 256
Whatever was causing you to see packet loss previously, we believe may have now been resolved. Can you let us know if you see anything from today onwards.
 Harry Beesley
chenks76
All Star
Fixes: 12
so what was causing it previously? when when was it resolved?
as it was still occurring on 18th.
chenks76
All Star
Fixes: 12
so i eventually get a response on my ticket, and to say it's ridiculous is an understatement.
it's clearly that the agent didn't even read the details of the ticket.
@HarryB care to comment?
Thank you for your query.
I've tested the line and there's no faults with this service, the connection is very stable, the speed is correct and I can see that the connection is used daily.
If you're having a technical issue please call us and speak to our technical support team, but the issue you're having doesn't need reporting to BT.
chenks76
All Star
Fixes: 12
also note that my upstream now seems to be capped at 888Kbps, whereas previously it was syncing at 1.2Mbps.
jelv
Fixes: 10
That indicates interleaving has been turned on.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
chenks76
All Star
Fixes: 12
which it wasn't before this packet loss problem started, and which i never asked for it to be turned on and was never advised it was turned on.
and guess what... PPP dropped again last night and i'm back on that "problem" gateway and the packet loss is back.
@HarryB still awaiting your comments.
44e7f41c84563323b9202d76c1280c08-24-10-2016
jelv
Fixes: 10
I can't see any significant packet loss on that graph.
chenks76
All Star
Fixes: 12
you'll notice between 8pm and 10pm the PPP connection dropped and re-connected.
between 2am and 7am you can see packet loss (significant or not it's there).
previous to the PPP drop there was virtually zero packet loss.
this only happens when connected to this specific gateway, which was the problem i reported (and totally ignored by the person who dealt with the ticket).
also, interleaving being enabled has apparently been done by stealth and not requested by me.
i ask that this is removed immediately.
Chris
Legend
Fixes: 169
Nor can I see that it was requested by us, it seems to have been put on automatically by DLM. I'll put a request in to change this back.
Can you share a live graph of your packet loss rather than individual screenshots? We'll be able to see when/if packet loss appears then.
What impact is the small amount of packet loss causing for your connection?
