Plusnet Call Protect
- Home Phone
- Plusnet Call Protect
27-04-2017 8:53 AM
Can this be used to blanket block international and withheld numbers, etc or can it only be used on a per number basis?
Re: Plusnet Call Protect
27-04-2017 8:57 AM - edited 27-04-2017 9:01 AM
Apparently you can https://www.plus.net/home-broadband/plusnet-call-protect
Not intending to hijack the thread, but it would also be useful to know if it is necessary to have Caller Display enabled for the Call protect feature to work.
27-04-2017 9:03 AM - edited 27-04-2017 9:07 AM
If i enable it will it mean i no longer get witheld calls ? When my work contacts me it shows up as withheld because of the type of place i work.
It sure sounds a good idea i just hope it dont affect the withheld calls i rely on.
27-04-2017 9:08 AM - edited 27-04-2017 9:13 AM
Thanks Maranello, missed that. I am pretty sure you must have to have CLI activated.
So is it a case of just dialling 1572 after my first international call and blocking it or is there any kind of web interface where I can set what to block?
27-04-2017 9:10 AM
There's no need to have Caller Display active for this to work @maranello
27-04-2017 9:10 AM
@St3 I think withheld will be the only problem as some legitimate callers such as hospitals etc use it. this is where a handset suct as BT8600 is a better bet.
27-04-2017 9:12 AM - edited 27-04-2017 9:18 AM
@JonoH morning
If i have this enabled on my phoneline will it prevent me from getting calls from the police or hospitals... doctors etc as these calls often show up as "witheld" and this could affect someones job or even life.
There is nothing here https://www.plus.net/home-broadband/plusnet-call-protect to say if it blocks calls from emergency services.
27-04-2017 9:18 AM
I'm surprised by this, I would have expected CLI would need to be active for the Call Protect feature to be able to block specified numbers. But I readily admit I know nothing about the technology
27-04-2017 9:19 AM
Have you selected to block withheld numbers or does it do this automatically? I would not want them blocked. most of my withhelds are legitimate.
27-04-2017 9:21 AM
I enabled it yesterday but now after reading the guidelines which i should have done anyways........ ive just removed it just incase.
27-04-2017 9:35 AM
you mean you enabled call protect or you asked call protect to block withheld numbers. I would not want them blocked automatically just because I have enabled call protect.
27-04-2017 9:38 AM
I enabled call protect but now i removed it just in case it blocks the withheld calls i get from work.
27-04-2017 10:00 AM - edited 27-04-2017 10:01 AM
Hi @St3
If a number is on our regularly updated list of know nuisance callers it will automatically be blocked, if you choose to you can divert other numbers (such as withheld or international numbers to your junk voicemail box.
As long as you check your junk voicemail you shouldn't miss any important calls and for those with withheld numbers dialling 1470 before the number you're trying to reach will reveal the number on that call.
I'd also like to make sure people with this facility turned on are aware that if you have a message in your junk mailbox, you will not be given the audio prompt to check it (the interrupted dial tone).
Hope this helps.
27-04-2017 10:04 AM
@JonoH so blocking withheld and international calls is optional and not a default when activating call protect? Are they activated as per and specific number - i.e by dialling 1572 after receiving one?
27-04-2017 10:36 AM
i just about to ask the same question @PhyllisTyne
