Permanently withhold number
Pooh
I notice that a few others have already posted in this forum about this, so hope this is the right place to make a request.
My Plusnet phone service started yesterday and I would like my number permanetly witheld when making out going calls please.
Can you also confirm that like BT, TalkTalk, etc, any calls I do want my number disclosed on just need to have the 1470 prefix inserted ?
Thanks.
6 REPLIES 6
MattyC
Fixes: 46
Re: Permanently withhold number
I've placed an order to withhold your number. I recommend checking your line in 24 hours.
Matty
Pooh
Hi Matty,
Thanks very much for doing this for me.  Once it's working I'll mark this as fixed.
Cheers,
Pooh.
Pooh
Hello again,
The change I requested has already been made - thanks.  However, it looks like I have misunderstood how permanently withholding my number works with Plusnet.
I had assumed that it would work the same way as it did when I was with TalkTalk and BT before that, i.e. your number was withheld for all out going calls, but you could release your number on a call-by-call basis by using the 1470 prefix.
I now get a message when dialling 1470 that this service is not available.
Do Plusnet use a different prefix to release your number ?
If it is not possible to configure the Plusnet telephone service to work as above, may I request it be put back as it was before ?
Sorry to be a nuisance.
MattyC
Fixes: 46
My apologies, I chose the wrong option. I've placed a fresh order with the option to override. Hopefully that should be sorted for you by tomorrow.
Matty
Pooh
Thanks Matty,
It now works perfectly !
Cool
MattyC
Fixes: 46
Great news, thanks for confirming.
