How do I change my call Plan
FIXED- Subscribe to RSS Feed
- Home Phone
- How do I change my call Plan
17-05-2017 4:01 PM
I know that I can change my call features but I cant see how I can change my call plan without contacting by phone.
Fixed! Go to the fix.
Re: How do I change my call Plan
17-05-2017 4:12 PM
Hi @oldg1t, you should be able to change your phone package through the product change section of the member centre Here.
When going through this process, you will first be asked to select a broadband package, however there should be the option to remain on the same package you're currently on.
After selecting the appropriate broadband package, you'll be given the options for call plans.
I hope this helps.
Please note, the price mentioned when going through the product change pages would not take in to account any discounts you currently have on your account if you have any applied.
17-05-2017 5:02 PM
Thanks HarryB
Followed your link and got to bit I want to remove (Plusnet Anytime) but I only see option to keep this product or go back. (See attachment)
Seems very long winded to change a minor item. Sledge hammer to crack a nut !
17-05-2017 5:21 PM - edited 17-05-2017 5:24 PM
Above that, does it not show the options for other call plans?
One of the call plans (Either Line only or Plusnet Weekends usually, depending on when you took out phone) should show the cost as £0.00 per month.
Here's a screenshot of my account:
- Home Phone
