Caller display displaying incorrectly
- Home Phone
- Caller display displaying incorrectly
Re: Caller display displaying incorrectly
06-04-2015 2:58 PM
As I said, this isn't going to get fixed unless it gets escalated and it's going to need someone in PN to champion your cause to do so!
Best of luck
06-04-2015 3:41 PM
06-04-2015 3:48 PM
06-04-2015 3:52 PM
PM me your number if so - I'll let it ring a couple of times (no need to answer as I'm only on evenings and weekends so it will cost me lmao).
Dom
06-04-2015 4:09 PM
Mark
06-04-2015 10:52 PM
07-04-2015 1:33 PM
Quote from: Marksfish I have to hope that on the day a BT engineer turns up and wastes my time that the number which previously rung had the problem (not every number has this issue).
MArk,
I suggest that this is a key piece of information - for clarity are you saying that your issue is only seen in respect of specific phone numbers, it does not happen on all numbers?
If this is the case, then I suggest that you need to make the number known to PN, as this all rather hints at issues related to routing of ported numbers or possibly management of VoIP calls.
Recently I have been getting spam phone calls from a spoofed Kingston-upon Hull number; sometimes it displays as 01482... and on other occasions as 001482.
I have drawn the conclusion that the spurious additional zero (making it look like an international number) is a facet of the call routing, not final delivery to the subscriber's line.
Kevin
07-04-2015 2:18 PM
It initially came through as "International" then quickly changed to a seemingly UK number. I wonder how they are managing to spoof numbers here.
07-04-2015 5:50 PM
Quote from: DomS I gave you a call at around 22:20 - apologies for the delay but I've been ripping out the kitchen this afternoon !
Ironically, your number displayed and was replayed correctly
07-04-2015 5:58 PM
Quote from: Townman I suggest that this is a key piece of information - for clarity are you saying that your issue is only seen in respect of specific phone numbers, it does not happen on all numbers?
It is not all numbers, but I cannot record all of them. The numbers are all correct and as expected, except for the extra 0 at the beginning. One call was from my Spanish bank, (not spoofed), one was from a call centre about my insurance (not spoofed) and another from a mobile number. Some nunmbers that are still in my phone (area codes only) are:
00746
00785
00776
008448
00754
00845
00034 (international)
0075300771
So quite a mixture of numbers!!
Mark
07-04-2015 6:00 PM
Quote BT wish to send an engineer to your premises to further investigate your home phone fault.
BT operate 2 timeslots for visits. These are AM ( 0800-1300) and PM (1300-1800), Monday to Friday
Please provide 3 timeslots you could attend and we will book the appointment for you and contact you to confirm when the engineer will be visiting.
Please note if an engineer visits your premises and is unable to gain access or If the fault is found to be caused by your equipment, internal wiring or as a result of damage to BT equipment a charge of £50 will apply.
Really? This is a voice fault, not a internet fault. Jumping through hoops for a service that the phone line was not designed for is one thing, but it was designed for voice calls. Seriously getting aggravated now
07-04-2015 6:03 PM
For identification of area codes, you need to give the 4 digits following any zeros. The last digit might separate mobile operator / number ownership.
Kevin
07-04-2015 6:09 PM
007763
008448
007543
008452
00034664 (international)
007539
007715
007588
001480
001702
Although it looks like all mobiles, there are other landline numbers too , but as they are known to me and picked up correctly in the caller display handset, I can't say which ones are also a part of this failure.
Mark
07-04-2015 7:57 PM
07-04-2015 7:59 PM
Mark
- Home Phone
