wifi sporadically connects. says incorrect password
- My Router
- wifi sporadically connects. says incorrect passwor...
16-02-2019 5:40 PM
Where to start..
I've phoned plusnet 3 times about this issue now. My phone does not always connect to the Wifi when I'm within range of it (2m away). The internet works on my desktop but that isn't wifi. I will walk in from outside and my phone will not connect to the wifi. it says connecting and "incorrect password" and then starts trying again. it can see the router and it has full signal. If I forget the network and reconnect it will connected straight away. if i turn the router off and on it will find it again straight away
Things they suggested that I have done -
1. do a factory reset of the router (held button for ages on the back until it reset)
2. split 2.4 and 5ghz channels
3. changed the channels so its not automatic
I then spent 30 mins on hold and 30 mins talking to a technical adviser who told me I should get a wifi extender, she told me this 3 times during the conversation and every time I explained to her that the range is not an issue. When I told her that restarting the router tends to allow my phone to connect or if i forget the network and reconnect again it works then she said I should perhaps try that again.
I have only been with plusnet two weeks and this is horrendous. I could just buy an off the shelf router but I'm paying for you guys to provide one so I'm not hugely happy about having to do that
Re: wifi sporadically connects. says incorrect password
16-02-2019 8:04 PM
4th call done, said because my house was made of stone it may be bouncing the signal around... even though my phone detects the wifi but says incorrect password. I'm not being funny but do they get training?
This is utterly ridiculous and then it got to 8pm when the call centre closes and the phone cut off. Customer service at its finest, thanks for that plusnet
16-02-2019 10:39 PM
Have you always had the problem, or has it only started recently?
Also be good to know what model phone and software version you're running?
17-02-2019 12:39 PM
17-02-2019 12:43 PM
Did a factory reset on my phone last night and router. Worked for 12 hrs without issue. Started again 20 mins ago. On hold to technical support again.
17-02-2019 2:44 PM
I'd forget 'Technical Support' and wait until @bobpullen is next available. He's the router guru.
18-02-2019 10:25 AM
18-02-2019 5:03 PM
20-02-2019 4:49 PM
@Greggorio, when did the problem start? Your firmware was updated back on the 9th February and I'm keen to establish if this coincides with your problems.
20-02-2019 5:26 PM
20-02-2019 5:34 PM
Ah, fair enough.
I notice the 2.4GHz and 5GHz radios are currently merged. When you tried splitting them did you experience the same problem with both SSIDs/radios or just one of them. If the latter - which one?
20-02-2019 5:42 PM
It hasn't done it today so far, so hard to test anything. Wish it was consistent to be honest. Makes tracking down issues easier. This is also the longest it's gone without doing it and I've not changed or moved anything
21-02-2019 8:26 AM
Hi @Greggorio
Hows everything looked since you lats posted? Still ok or are you seeing issues again?
- MoR
04-03-2019 1:53 PM
@Greggorio curious to hear whether or not you're still experiencing this problem?
15-05-2019 7:47 PM
I’m sure it’s a router issue. I have 5 Google speakers which randomly drop connection. A reset of the router normally sorts this.
But surely doing this 3 times a day isn’t either normal or acceptable? Furthermore I can’t actually call during the day so feel alone and frustrated with this issue. I’ve even considered paying to get out of my contract, which I have another 9 months off
- My Router
