wifi dropping ev few seconds
jandaco
Hi, my wifi connection is dropping continuously and reconnecting. here is some of the event log.which I would sent if this machine stayed online long enough..
5 REPLIES 5
Mav
Fixes: 515
Re: wifi dropping ev few seconds
Moderator's note:
Thread moved from Fibre Broadband to My Router.
Forum Moderator and Customer
bill888
Champion
Fixes: 38
What model router, and wifi devices are you using ?
https://www.plus.net/help/broadband/router-setup-guides/
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
jandaco
I have a hub one router on FTTC, My Wifi devices are a Chromebook (Acer R11) a one plus6 phone and two other Android devices. There are TV and Youview boxes but wired with mains plug links.
The Acer  Chromebook is the device I notice the problem on.
bill888
Champion
Fixes: 38
Acer R11 is a dual band wifi device.
Try splitting the 2.4 and 5 GHz wifi and renaming the 5 GHz wifi.
https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/td-p/1351950
Then see if the Acer maintains a stable connection if connected to either 2.4 or 5 GHz wifi.
jandaco
Thanks bill888,
I have done that and will report back on how it goes. I am using the 5 Ghz connection now and will change to the 2.4 if it drops.
