wifi drop outs
- My Router
- Re: wifi drop outs
wifi drop outs
15-12-2019 7:58 PM
Had my plusnet broadband for a few months now speed approx 21 when plugged into main socket. Managed to increase this to 26 when router plugged into test socket. This has been ok until about two weeks ago when my wifi started to drop out on any mobile phone connected to the router this is happening frequently in the evening when the phones are using the wifi. The phones are connecting to 5ghz band. I still have my bt router can i use this to connect to plusnet to see if that helps.
Re: wifi drop outs
16-12-2019 8:41 AM
Moderators Note
This topic has been moved from Fibre to My Router.
Re: wifi drop outs
16-12-2019 8:36 PM
Hi @fp55zxf
Sorry to hear that you're experiencing wifi issues - you can indeed use many BT routers instead of your Plusnet one.
You'll need to manually enter your login details via the Hub's internal menu and that should then connect as normal.
If you post which BT router you're looking to use, either myself or a community member will provide information on how to do this.
Best wishes
Dave
