wifi channels
Harman890
wifi channels
I cannot seem to connect with the hub one web page to change my wifi channels. My wifi connection has fallen off regularly and i the channel was changed on Tuesday and made no difference.
To gain access to the hub one page i am using Chrome and this number 192.168.1.254 but it will not connect
8 REPLIES 8
Legend
Fixes: 255
Re: wifi channels
Welcome to the forums, @Harman890 . Can you be a little more specific - what response do you get when you type the web address into the title bar on your router - not a search bar?
Harman890
Re: wifi channels
Hi John
I am not getting any message it just will not connect
Fixes: 1,483
Re: wifi channels
Moderators Note
This topic has been moved from ADSL Broadband to My Router
Legend
Fixes: 255
Re: wifi channels
@Harman890 That does not make sense. I don't use Chrome, but what indication do you get for activity, or lack of?
Harman890
Re: wifi channels
i just get the site cannot be reached, connection timed out
Legend
Fixes: 255
Re: wifi channels
I am mystified - if you are connected to the router and type that into the address bar, you should get it almost instantly.
@Baldrick1  - any idea?
Harman890
Re: wifi channels
sorted.
Legend
Fixes: 255
Re: wifi channels
How?
