whos using my wifi
Chazza88
whos using my wifi
hi, i cant seem to find the optiong in my router settings to see who is connected to my wifi.
any help will be appreciated.
thank you
5 REPLIES 5
Re: whos using my wifi
Hi @Chazza88 welcome to the forum
which hub do you have?
If it's a Hub Two and you're on your home network click here http://192.168.1.254/basic_-_my_devices.htm
HTH
Chazza88
so sorry, ive totally no clue. how do i find out? please
that lin isnt working.
Check here https://www.plus.net/help/broadband/router-information/
For a Hub One the home page will tell you http://192.168.1.254
Chazza88
just by luck i have found it. thank you tho
Fixes: 480
Moderator's note:
Thread moved from Broadband to My Router
