where is dynamic DNS configuration dialog in hub one
eastayrshire
as title, just received this, serious chance i am just stupid
14 REPLIES 14
Fixes: 1,600
Re: where is dynamic DNS configuration dialog in hub one
Hi there.
Could you post up a screenshot of what you're seeing?
eastayrshire
It's what I'm not seeing that's the issue so to post meaningful screenshots would be to post every configuration screen, I might just be missing where the option is .
eastayrshire
adamwalker
Fixes: 221
I'm not aware of where that is. The relevant people I'd need to ask aren't available at the moment so I'll come back to you and tag @Browni in the meantime who posted the image in the thread you linked to.
Adam
 Adam Walker
eastayrshire
Browni
Aspiring Hero
Fixes: 60
I don't have easy access to a Hub One at present but can assure you that screenshot is from a Hub One as that was the only Plusnet supplied router I used. The giveaway is the pink option buttons Smiley
eastayrshire
I'm either stupid (entirely possible), or perhaps a different iteration of firmware
Browni
Aspiring Hero
Fixes: 60
Are you sure it's a Hub One you have?
I don't know if the Hub Zero supported this function.
eastayrshire
Definitely a hub one
Mustrum
Fixes: 77
I don't have easy access either at the moment, but I believe it's in the Advanced Tab, either Firewall or Home Network. Why not have a look?
eastayrshire
I did look , couldn't see it, it's at my parents house, it's not a huge deal inasmuch as a static IP for £5 fixes it etc but I was sure it would be there
eastayrshire
It's under the broadband tab , I was indeed an idiot, thanks to all who replied & helped with their time
Browni
Aspiring Hero
Fixes: 60
Yay! I'm glad you found it in the end Smiley
eastayrshire
Age related cognitive decline 😞
