vodafone sure signal V3 and plusnet hub one
- My Router
- vodafone sure signal V3 and plusnet hub one
21-05-2016 8:55 PM - edited 21-05-2016 8:56 PM
I have a VSS V3 which has stopped working. before I go to Vodafone is there anything I should do to my plusnet hub one to maybe get this thing working as I have no lights only the Ethernet port is on on the VSS.
cant find the smart setup off option which is suggested to be turned off.
I have tried resetting the VSS to no avail.
Re: vodafone sure signal V3 and plusnet hub one
22-05-2016 10:07 AM
Was this previously working with PH1?
22-05-2016 10:29 AM
No, this was the first setup of PH1, however I left everything plugged in last night after trying various reset options and this morning the VSS was lit up and working fine.
PH1 working fine, so all good.
- My Router
